SolaraGuy.com • View topic - blown fuses/bad input stage
Postby Callen » Thu Jul 15, 2004 9:27 am
My amp's blowin' fuses every time I turn the HU on (remote to remote wire). However when I turn it on connecting the battery lead to the remote,, it runs at a steady 12.4 (obviously with no sound). I did a little bit of research and found that this might be a "bad input stage". Ugh,,,, research over the internet didn't do much from there searching for an array of things at other audio forum sites and google.
First: Does anyone know the best route to go on this?
Second: does anyone know any really good car audio forums (besides this one!).
Third: What happens when a magnet is introduced to the grounding wire of the Head unit,,,, can that make the amp short?
2 JL 12w6's powered by
Hifonics BX1000D amp@ 1.5 ohms run off an
Alpine CDA-9833
soon to be
CDT EF61CFi/25 6.5" components.
Callen
Postby kubi » Thu Jul 15, 2004 9:34 am
sounddomain.com
Please stop humping my car, owner privilege!
kubi
Postby Callen » Thu Jul 15, 2004 10:10 am
kubi wrote:sounddomain.com
Good forum.
Alpine CDA-9833
soon to be
Callen
Re: blown fuses/bad input stage
Postby pro956 » Thu Jul 15, 2004 10:44 am
Callen wrote:My amp's blowin' fuses every time I turn the HU on (remote to remote wire). However when I turn it on connecting the battery lead to the remote,, it runs at a steady 12.4 (obviously with no sound). I did a little bit of research and found that this might be a "bad input stage". Ugh,,,, research over the internet didn't do much from there searching for an array of things at other audio forum sites and google.
okay, from what u told me over im
you should have had a better ground spot-- not the frame that holds the head unit in
and when you were screwing the head unit in, it touched two sources of metal that sent an electrical signal through the screw driver
sounds like you need to have your headunit repaired or get a new one
why does it run obviously with no sound? you should get sound as long as the rca's are in and the amp turns on
i'm posting my responses on here and not back to you on im so other ppl can add on or learn or correct me or whatever
AIM: pro956
2002 5-speed se v6
pro956
Postby Callen » Thu Jul 15, 2004 10:46 am
Oh yeah, HU stil works fine....
HU Remote----amp remote+power=blown fuses
HU battery lead-- amp remote= 12.4 volts.
Alpine CDA-9833
soon to be
Callen
Postby pro956 » Thu Jul 15, 2004 10:55 am
get a long small wire, stick a small fuse on it, make sure it's safe for the amp to see 12volts+ to the remote turn on, connect it to the amps remote turn on and wire up a switch
turn it on and off when you want to run the amp
this is quite stupid, but it will work
if you leave it on by mistake, your battery will drain
get the head unit fixed
or get a new one and be more careful during the install
AIM: pro956
2002 5-speed se v6
pro956
Postby Callen » Fri Jul 16, 2004 12:13 am
replaced the amp
Alpine CDA-9833
soon to be
Callen
