SolaraGuy.com • View topic - People running two amps read please
Postby oompah2788 » Mon Jul 19, 2004 1:59 am
People with an amp for speakers and a seperate amp for subs, what size power wire do you use from the batt to the d-block, and what size from d-block to amps??? I am going to be running two amps, one putting out 100x2 and the other 400x1, and was wondering if 4gauge from batt to distro and 8 from distro to amps is too small?? 1/0 gauge is pretty expensive and pretty fat! Can 1/0 gauge still be routed through that one hole that you drill behind the "white plastic proppeller thing" on the upper left of brake pedal??? sorry if this is confusing!! THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :D :bday: :angel:
oompah2788
Postby i20solara02i » Mon Jul 19, 2004 2:47 am
im running both of my amps with 4 gauge wires
i20solara02i
Postby SoLaRa_PimPin99 » Mon Jul 19, 2004 1:26 pm
I'm also running both amps with 4-gauge wire!
99 Solara SE V6 Black w/ Blue Pearl (New Paint job)
19" Niche F-16 (215-35-19 Nitto gen's)
Eibach Pro-kit
Tokico Blue Struts
Dual Cat-back Exhaust
Altezza Carbon Fiber tailights
SoLaRa_PimPin99
Postby WortownSolara » Mon Jul 19, 2004 1:27 pm
you are very borderline, no one around you has 2 gauge? But on the plus side, you wont cause any fires with 4 gauge
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
Postby indiglosolara » Mon Jul 19, 2004 2:19 pm
4 gauge from batt to d-block.. then 4 to amps also....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby oompah2788 » Mon Jul 19, 2004 4:32 pm
rufus and solara pimpin - you guys are running all 4 gauge?? so 4 gauge from batt to distro, then 4 from distro to amps??
what kind of amps you guys running??
wortown- you know how fat 2 gauge is?? i heard 1/0 is around the size a of garden hose!!! :o and they are pretty expensive....
THANKS!!!! :D
oompah2788
Postby i20solara02i » Mon Jul 19, 2004 6:13 pm
i20solara02i
Postby oompah2788 » Mon Jul 19, 2004 6:48 pm
wahhh! :o nice!!! all focals.... and utopias too!! 8) *drool* haha. you got quite some money to spend huh. so all that and youre only using 4 gauge all around??? youre site didnt say what you were running from batt to distro... just said monster cable wiring... so youre using 4 frm batt to distro and 4 to everything else??? nice car once again! :D
oompah2788
Postby Jackass-Jeff » Tue Jul 20, 2004 12:32 am
oompah2788 wrote:wahhh! :o nice!!! all focals.... and utopias too!! 8) *drool* haha. you got quite some money to spend huh. so all that and youre only using 4 gauge all around??? youre site didnt say what you were running from batt to distro... just said monster cable wiring... so youre using 4 frm batt to distro and 4 to everything else??? nice car once again! :D
he bought all his speakers/subs for $3 and whored up the rest ;-) hahaha
1GR-FE ftw!
Jackass-Jeff
Postby SoLaRa_PimPin99 » Tue Jul 20, 2004 8:07 am
I'm running a Hifonics Zeus to my Sub. and a Hifonics Zeus to my Highs and Mids!
Eibach Pro-kit
Tokico Blue Struts
SoLaRa_PimPin99
Postby Jackass-Jeff » Tue Jul 20, 2004 11:20 am
I'm running 4 gauge wiring to 2 amps. A monoblock D class 1000 RMS/2000 peak amp, and a ~400 RMS/800 peak 4 channel amp for components. Both Eclipse. No lack of power or dimming lights for me :D
The gauge depends on the amount of power. If the amp recommends 4 gauge, then use a bigger wire from the battery to the d-block and then use 4 gauge wires. That way, you'll have power coming in and being distributed correctly. 100% to 50%/50% as opposed to 100% to 100%/100% wires that are too big, hence giving more resistance x_x
something like that, anyhow
CAPACITOR? What's that ? :P
1GR-FE ftw!
Jackass-Jeff
Postby oompah2788 » Tue Jul 20, 2004 10:07 pm
for the 2 ch. amp it says:
up to 10' ---- 4 or 8 gauge up to 20' ---- 4 gauge only
and for the mono amp it say:
up to 70' --- 4 or 8 gauge up to 20' ------ 4 gauge only
i dont know if the numbers are in feet.... but i think the instruction for the mono amp is a typo cause wouldnt you need thicker wire if your running it very long and vise versa??? maybe they meant to put 7' not 70'??
confused....
help me out here... THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :D
oompah2788
Postby groovespacer » Wed Jul 21, 2004 9:59 pm
You're fine with the 4 to 2 8's. The 4 definitely holds enough current to feed both those amps, but you might wanna go big so you have room to upgrade later.(just an option)If you upgrade the wires later it'll be pricey. I happen to have a spindle of 0 gauge wire by the way.
groovespacer
Postby oompah2788 » Wed Jul 21, 2004 11:54 pm
anyone know what the maximum current(amps) a 8 gauge wire can flow??? i heard 4 gauge is like 150amps..... Thanks
oompah2788
Postby groovespacer » Thu Jul 22, 2004 1:14 am
About half a 4 gauge, which is allot of amps. I bet your Circuit breaker or fuse will not even be close to around 80(even for your sub amp)..but u may wanna upgrade later. so keep that in mind.
groovespacer
