SolaraGuy.com • View topic - installing an amp
installing an amp
installing an amp
Postby jerm781 » Sat Jul 24, 2004 4:04 pm
Hi I'm new here and I'm wondering if anyone has put a amp to the stock radio? If so what wire do you use for the amp remote on/off and how do you get the radio out? Thanks in advance for any help
jerm781
Postby krawzyazn » Sat Jul 24, 2004 5:28 pm
umm this should be in the Audio Video section
Re: inatalling an amp
Postby Mole » Sat Jul 24, 2004 9:13 pm
jerm781 wrote:Hi I'm new here and I'm wondering if anyone has put a amp to the stock radio? If so what wire do you use for the amp remote on/off and how do you get the radio out? Thanks in advance for any help
since this is going into AV section, list what year car you have.
do you plan to amp the speakers?
Postby trdpower04 » Sun Jul 25, 2004 4:19 am
Well, i installed an amp to run my subwoofer, and I found a spare fuse in the fuse box under the hood that has power only with the ignition on, which you want unless you would like your amp to stay on all of the time...
I am not sure why you are wanting to take the radio out, I am guessing for RCA cables? Well, don't bother because you won't find RCA jacks on a stock radio. Go to an A/V store and get yourself a low-line convertor, which takes your signal from the speaker wires and converts them to the proper signal for your amp. This will have to do until a stereo installation kit comes out for the 04 Solara. Not the best way, but about the only way for now. Hope this helps.
2004 Toyota Solara SE Sport V6
Arctic Frost Pearl
trdpower04
Postby jerm781 » Sun Jul 25, 2004 7:46 am
Its a 04 Solara. How do do you use the spare fuse as the remote source. I've never done it that way.
jerm781
Postby gogeta » Sun Jul 25, 2004 9:02 am
wrap the end of the wire around the bare metal of the fuse...then plug the fuse back in....one of the most"ghetto ways to do it but hey wutever works right....i have an rca converter to my amp and from a stock deck my shtoof bumps.....
arctic frost pearl/gray 04 se
trd exhaust/air filter
mb quart 2 way 6x9s front
eclipse 4-way 6x9s rear
kicker kx 600.1/kicker l7 dual 2ohm
alpine head unit itching to be put in...
gogeta
Postby jerm781 » Sun Jul 25, 2004 2:25 pm
thanks for the info.
jerm781
Postby Callen » Sun Jul 25, 2004 5:53 pm
trdpower04 wrote:Well, i installed an amp to run my subwoofer, and I found a spare fuse in the fuse box under the hood that has power only with the ignition on, which you want unless you would like your amp to stay on all of the time...
who ever said he's getting a sub amp?
2 JL 12w6's powered by
Hifonics BX1000D amp@ 1.5 ohms run off an
Alpine CDA-9833
soon to be
CDT EF61CFi/25 6.5" components.
Callen
Postby jerm781 » Sun Jul 25, 2004 10:03 pm
actually I am hooking up a sub amp and later an interior speakers amp.
So I can use any fuse thats on when the ignition is on right???
jerm781
Postby cklinh » Tue Nov 30, 2004 9:47 pm
Sorry to bring back this old topic, but does anyone know of another place to connect the remote wire?
I'm gonna be installing the amp/sub with a friend, and would like to hammer the details out before we start...
Nevermind, I guess :)
Found _some_ possible locations in another thread... cigarette lighter... sideview mirror... anything I can find... :)
cklinh
