SolaraGuy.com • View topic - Buzzing Noice!
Buzzing Noice!
Buzzing Noice!
Postby retarded » Sun Aug 15, 2004 4:16 pm
wassup guys..I FINALLy just installed some infiniti speakers into my car powered by an infiniti amp as well. theres one big problem though, whenever I accelerate I hear this buzzing noice that gets louder as I accelerate in my speakers. WHen my volumes low, the noice is more noticeable. People tell me its my wiring, I've checked, and I see nothing wrong. Could it be that I have a factory head unit?
retarded
Postby mtodde » Sun Aug 15, 2004 4:21 pm
Did you run the power cable down the same side as your RCA interconnects? That's what it sounds like...I had that problem in my last car and had to re run the interconnect down the passenger side instead.
2004 Solara V6 SLE
Lunar Mist Metallic
2 time Solara owner (1999 SE V6 MT)
http://www.cardomain.com/memberpage/648891
mtodde
Postby bassthrive » Sun Aug 15, 2004 7:41 pm
You need a more solid ground.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Mole » Sun Aug 15, 2004 7:52 pm
it is electrical interference. do what the others said above by separating the wires.
Postby retarded » Mon Aug 16, 2004 12:04 am
thanks guys.yup they are on the same side. i'll try separating them and let u know what happens.
retarded
Postby HKSV6SLE » Tue Aug 17, 2004 12:53 am
too many wires= interference. :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby WortownSolara » Tue Aug 17, 2004 6:54 am
just a side note, most RCAS available today have MORE than enough shielding to block EFI. That being said, seperate them =0p
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
Postby B_Master_Flash » Tue Aug 17, 2004 2:21 pm
The noise you hear is interference from the alternator. Make sure you have a solid ground point, sand the paint away and make sure its bolted down tight. and of course make sure your RCAs are at least a foot away from your power wires.
B_Master_Flash
Postby retarded » Thu Aug 19, 2004 9:03 am
The thing is I'm not using any RCA cables because I still have a stock head unit. So I should just separate my speaker wires from my power wires basically?
retarded
Postby Duffman » Tue Aug 24, 2004 9:07 am
Hmm, dunno if the speaker wires would cause that interference. It's possible I guess. Did you check your ground wire? I had a similar problem in my 91 Camry until I sanded down the metal around the ground connection and bolted it down better.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby WortownSolara » Tue Aug 24, 2004 10:21 am
using a hi-to-low converter inside the amplifier, or crossing the speaker wires and power, within 18 inches of the amp, could induce noise into the converter. I do wonder now that if the ground is solid, more along the lines of the paint not being stripped off around the ground..though someone already said that :wink:
WortownSolara
Audio Guru
Audio Guru
Users browsing this forum: Google [Bot] and 9 guests
