SolaraGuy.com • View topic - sub/amp/high-low converter problem???
Postby s e y t o n » Sat Aug 21, 2004 11:37 pm
whenever i turn off my head unit, my sub hits at a constant full force. only way to stop it is to turn the head unit back on.
this happened to me about twice (in a span of about 2 months) before i put in my new sub today. but now it happens every time. im thinkin it (the consistency) might be due to changing some settings on the amp after todays install. the only difference in my system as of today is i swapped out my old pioneer sub for a new fosgate sub.
any ideas as to why this is happening?
my current sound system set up:
-stock head unit & interior speakers
-high-low converter
-pioneer 760 watt amp
-fosgate punch 12" sub
-Sam
Black 2000 5s-fe 5 speed - "Blackie"
s e y t o n
devilish solaraguy
devilish solaraguy
Postby Jackass-Jeff » Sun Aug 22, 2004 7:13 am
upgrade to eclipse?! =P j/k
It may be due to that fact you don't have a remote amp power on line (upgrade the headunit!) I don't know why the subs hit, but I'm sure part of the problem is the remote on
Good luck!
1GR-FE ftw!
Jackass-Jeff
Postby geminimouse » Sun Aug 22, 2004 7:21 am
What are u using for the remote to the amp?
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Jackass-Jeff » Sun Aug 22, 2004 7:25 am
geminimouse wrote:What are u using for the remote to the amp?
the only thing is probably a constant 12 lol
1GR-FE ftw!
Jackass-Jeff
Postby krawzyazn » Sun Aug 22, 2004 7:49 am
no no no
you need to turn the gain down it used to happen to me tooo
Postby s e y t o n » Sun Aug 22, 2004 11:52 am
turn the gain down? how would i go about doin that? sorry, i didnt do the install myself so i dont know too much about the technical side of this stuff..
-Sam
s e y t o n
devilish solaraguy
devilish solaraguy
Postby krawzyazn » Sun Aug 22, 2004 10:14 pm
the gain should be on your amp hmm i wonder how they wired it up
if anything take it back to the shop and the'll do it for you
Postby HKSV6SLE » Sun Aug 22, 2004 11:05 pm
turning the gain down should help. the gain is usually on the back of the amp little knob. :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby s e y t o n » Tue Aug 24, 2004 12:10 pm
ok so i turned the gain down to a point where the sub wouldnt hit when i turned the head unit off. but the sub would be barely hitting when the head unit was on... so i turned the gain back up to the way it was... is this pushing my sub too hard or causing any potential problems? can i just leave it like this and never turn the head unit off? any other ways of fixin this without takin away all the power from the sub?
-Sam
s e y t o n
devilish solaraguy
devilish solaraguy
Postby cdeez » Wed Aug 25, 2004 10:07 am
hey, this might be able to help you http://www.zer0.info/solaraguy/viewtopic.php?t=10363 just scroll down a bit and you may find out way to fix your problem. hopefully.
last standing...
Socalara...
cdeez
Users browsing this forum: Google [Bot] and 9 guests
