SolaraGuy.com • View topic - Which amplifier?
Which amp to choose?
Alpine MRV F450
1
6%
AudioBah A6601T
0
No votes
Eclipse PA 5532
1
6%
JL Audio E6450
1
6%
Kicker KX700.5
2
11%
MTX Thunder 895
1
6%
Phoenix Gold Octane R.9.0:5
3
17%
Soundstream Van Gogh VGA 800.5
2
11%
Viper 1100.5
1
6%
Xtant 403A
4
22%
They all suck.... :)
2
11%
Total votes : 18
Which amplifier?
Which amplifier?
Postby Fenix » Wed Sep 01, 2004 10:08 am
Guys,
I'm looking to upgrade my stereo system in the rear future. Since I refer the simple style, I decide to go with a 5 channels amplifier to power 2 fronts,2 backs and a sub.
The following amps are what I've been looking at, in your opinion which amp is the best of the bunch?
Budget for the amp is up to $350.
The power is for RMS.
Alpine MRV F450 50 x 4 + 200 x 1
AudioBah A6601T 75 x 6
Eclipse PA 5532 50 x 4 + 200 x 1
JL Audio E6450 45 x 6
Kicker KX700.5 40 x 4 + 200 x 1
MTX Thunder 895 50 x 4 + 240 x 1
Phoenix Gold Octane R.9.0:5 125 x 4 + 400 x 1
Soundstream Van Gogh VGA 800.5 50 x 4 + 200 x 1
Viper 1100.5 74 x 4 + 275 x 1
Xtant 403A 50 x 2 + 100 X 1 (gonna buy two of them)
Please vote, thanks.
R.I.P baby.
Here come the black on black 5spds. New era....
Fenix
Postby indiglosolara » Wed Sep 01, 2004 10:36 am
if you go with the JL audio use the Jl Audio 500/5, its better then the E series.
Also it depends ont he sub your going to run. I woul say get all your inside speakers and subs then choose the amp to meet the power requirements.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby gogeta » Wed Sep 01, 2004 2:28 pm
in my opinion nothing beats kicker....have had 0 and i mean 0 problems with it....even when my dumbass hooked the power to the ground and ground to power...fried fuses left and right....and the thing still bumbs like its brand new......
arctic frost pearl/gray 04 se
trd exhaust/air filter
mb quart 2 way 6x9s front
eclipse 4-way 6x9s rear
kicker kx 600.1/kicker l7 dual 2ohm
alpine head unit itching to be put in...
gogeta
Postby pro956 » Wed Sep 01, 2004 7:59 pm
gogeta wrote:in my opinion nothing beats kicker....have had 0 and i mean 0 problems with it....even when my dumbass hooked the power to the ground and ground to power...fried fuses left and right....and the thing still bumbs like its brand new......
you said it right "dumbass"
you really shouldn't be giving advice when you did something like that
there's always something better than what you have
and in your case, the list is huge
AIM: pro956
2002 5-speed se v6
pro956
Postby HKSV6SLE » Wed Sep 01, 2004 9:58 pm
given those i say xtant :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Jaimster » Wed Sep 01, 2004 10:06 pm
I have MTX and always have... those amps Rock!
My Amp: 1000D - Mono class D amp
Thunder 1000D Amplifier
RMS POWER (12.5 Volts DC):
500 Watts x 1 into a 4 Ohm load with less than 0.5% Thd+N
1000 Watts x 1 into a 2 Ohm load with less than 1% Thd+N
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
850 Watts x 1 into a 4 Ohm load
1500 Watts x 1 into a 2 Ohm load
Signal to Noise Ratio:
100dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-200Hz
Maximum Input:
8Vrms
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
EBC External Bass Control
Crossover:
Variable 40Hz to 200Hz, 24dB/octave low pass
Dimensions:
14” x 9” x 2” (35.6cm x 22.8cm x 5cm)
15-1/4” x 9” x 2” 38.7cm x 22.8cm x 5 cm) Including IsoFeet™
http://www.mtxaudio.com/caraudio/archiv ... r1000d.cfm
Jaimster
Postby krawzyazn » Wed Sep 01, 2004 10:15 pm
kicker is my choice :lol:
Postby Jackass-Jeff » Wed Sep 01, 2004 10:39 pm
Sony XPlod! :lol:
1GR-FE ftw!
Jackass-Jeff
Postby B_Master_Flash » Sun Sep 05, 2004 6:32 pm
I voted viper but any of the 4 on the bottom are good. The eclipse and the JL are good too.
B_Master_Flash
Postby ZXLNT » Wed Sep 08, 2004 3:38 am
Wheres the old stuff like the Orion HCCA's or the PPI ART class. Thats my vote. :)
ZXLNT
