SolaraGuy.com • View topic - Is It Enough?
Is It Enough?
Is It Enough?
Postby Parke10 » Sat Sep 11, 2004 7:35 pm
Is
2 5 1/4 JBL 2-ways Speakers
1 360 Watt JBL Amp
1 Kicker L7 8"
Good enough for a single cab tacoma? fer just a good basic system?
Parke10
is it enough??
Postby SleeperSolara » Mon Sep 13, 2004 7:53 am
Yeah the 360 amp should do good, for the 8" L7.
I have a 10" L5 and i bumped it a couple of times wit a 300 watt amp, and was feelin' the vib in my back. I also put 500 watts to the same sub i have wit no remote that came wit it, and it was bumpin' loud as hell. No only if i had the remote bass in, i would be loud like no other.
Plus my L5 is custom ported on the back side of the box behind the sub.
[If you look at the ported box Kicker suggests, think of my port on the back piece of the box, behind the sub.]
Damn only if i could put it back in.
Got to make another box for it, porbably.
Are you goin' sealed, or ported??
If you live close to OKC, i could make one for you, probably make it custom fitted to your trunk in case someone trys to break in the are goin' to have a hell of a time to try to get it out.
Re: is it enough??
Postby pro956 » Mon Sep 13, 2004 10:54 am
SleeperSolara wrote:Yeah the 360 amp should do good, for the 8" L7.
the remote bass could already be turned all the way up
so maybe not...
AIM: pro956
2002 5-speed se v6
pro956
Is it enough
Postby SleeperSolara » Tue Sep 14, 2004 8:06 am
Nope i never got to put in the remote bass. :(
Oh well my sub and box is just sittin' in my room right now.
Right now i got Alpine Type S on all four stereo corners, got to make MDF mounts for them.
Re: Is it enough
Postby pro956 » Tue Sep 14, 2004 11:08 am
SleeperSolara wrote:Nope i never got to put in the remote bass. :(
right, but it may already be all the way up-- like i said before
AIM: pro956
2002 5-speed se v6
pro956
Postby B_Master_Flash » Mon Sep 20, 2004 10:11 am
Most remotes are the equivalent of having them turned all the way down if you detach them, but some are turned all the way up. Also, even if your remote is turned all the way down (depending on the model, they all work differently) you should be able to set the gain to compensate for it.
B_Master_Flash
