SolaraGuy.com • View topic - CAR PC Suggestions
CAR PC Suggestions
CAR PC Suggestions
Postby Willy7o2 » Wed Nov 03, 2004 4:37 pm
I want to put a PC in my car .... I'm concerned about the following... please help:
Where would the 7" Touch Screen Go?
Should I replace my CD-Changer with the Car PC?
Would I need a new amp if I do take the CD-Changer out?
Are the any Car PC Products that work as a normal CD-Player without powering up the O/S. Windows loadup takes so long, sometimes I just wanna listen to a CD and go.
Anything else to be concern about?
2004 Solara V6 SLE
TRD FSTB+RSB & Muffler
K&N High Flow Air Filter
Front GFX Lips
Mike T's Custom Grill Combo
Limo-Tint All Around
Willy7o2
Re: CAR PC Suggestions
Postby Jackass-Jeff » Wed Nov 03, 2004 8:40 pm
Where would the 7" Touch Screen Go? Get a flip screen dvd player w/ touch screen capabilities! Replace your factory one w/ that (do they have the gen 2 stereo 'plastic thingy' yet ?)
Should I replace my CD-Changer with the Car PC? You need the touchscreen player! Sound processing straight from a PC w/o an amp would suck
Would I need a new amp if I do take the CD-Changer out? Yes, unless you get the touch screen
Are the any Car PC Products that work as a normal CD-Player without powering up the O/S. Windows loadup takes so long, sometimes I just wanna listen to a CD and go. - Yes MSI makes a "to go" PC that's small and you can independently operate the CD player or radio w/o turning the computer all the way on.
Anything else to be concern about? Power supply! You have to hardwire it if it's more than 150 watts (and a PC will obviously be more) and you may have to worry about generator noise from the ac/dc adapter you need! Good luck!
1GR-FE ftw!
Jackass-Jeff
Postby pythonjosh » Wed Nov 03, 2004 10:27 pm
Go here:
http://www.zer0.info/solaraguy/viewtopic.php?t=7127
It's in the Pictures forum.
pythonjosh
Postby HKSV6SLE » Fri Nov 05, 2004 4:58 am
there this new car computer thing they hve an in depth review in last months car and audio mag.....i would get it. :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
