SolaraGuy.com • View topic - audio porblem
audio porblem
audio porblem
Postby whiteflash » Sun Nov 28, 2004 7:20 pm
ok i got a problem i have all alpine typre speakers all around hooked up to a 840 watt amp then i have it goinng to a 2.4 capacitor which then goes to a amp now the amp stays on protect for some reason all the grounds are good the fuses are fine theres enough power goin to the cap but still it stays on protect ...any ideas?
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Re: audio porblem
Postby geminimouse » Sun Nov 28, 2004 8:07 pm
whiteflash wrote:ok i got a problem i have all alpine typre speakers all around hooked up to a 840 watt amp then i have it goinng to a 2.4 capacitor which then goes to a amp now the amp stays on protect for some reason all the grounds are good the fuses are fine theres enough power goin to the cap but still it stays on protect ...any ideas?
so u have a 840watt amp that powers ur alpine type r speakers. Then u have the power wire from the 840w amp going to a 2.4cap which then goes to another amp?
sorry..what u said was kinda confusing
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby whiteflash » Sun Nov 28, 2004 9:33 pm
yep sorry for being confusing but yes that is right
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby geminimouse » Tue Nov 30, 2004 7:35 am
did u check ur remote wire and rca cables?
08 Accord Coupe
geminimouse
Postby WortownSolara » Tue Nov 30, 2004 9:18 am
check the impedence on the speakers..............
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
