SolaraGuy.com • View topic - Problem with sub and amp
Postby StockSolara » Thu Dec 23, 2004 1:32 am
I'm trying install the amp and sub into my car and the way my set up was to have a two way splitter for the wires in the back speakers to go into the amp and then the sub. The problem is that when ever I turn off the car and turn it back on the sub and the back speakers do not work but when I unplugged the speaker wires from the amp it rear speakers go back on and then I plug it in the sub works again. So I really can not figure out why when I turn off my car the sub and rear speakers would not work.
Thanks ahead of times for your input
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby StockSolara » Fri Dec 24, 2004 1:04 pm
alright seems like no one knows the answer to my previous question well now i have another. . . me and my dad tried another approach to run RCA wires from the head unit. . . but the stock one DOES NOT have them. . . I was wondering if any of you guys can please help me out on this wiring.
2000 Lexus GS400
StockSolara
Re: Problem with sub and amp
Postby B_Master_Flash » Fri Dec 24, 2004 11:26 pm
StockSolara wrote:I'm trying install the amp and sub into my car and the way my set up was to have a two way splitter for the wires in the back speakers to go into the amp and then the sub. The problem is that when ever I turn off the car and turn it back on the sub and the back speakers do not work but when I unplugged the speaker wires from the amp it rear speakers go back on and then I plug it in the sub works again. So I really can not figure out why when I turn off my car the sub and rear speakers would not work.
a little grammar goes a long way. I read that over about 3 times and I still have no idea how you have your stuff wired.
B_Master_Flash
Postby Mole » Sat Dec 25, 2004 12:07 am
is the amp powered on when the sub does not work?
Postby bassthrive » Sat Dec 25, 2004 7:47 am
Check that the remote wire is secure if the amp wont switch on properly. Also, if you are tapping into your 6x9's you better be using some sort of speaker-level input. RCA's from the headunit are still the best way to go I think. How many watts are you pushing and what gauge wire is delivering the power?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby 562solara02 » Wed Dec 29, 2004 2:43 am
well u might want to take it to a shop and get it done the right way, u dont want to mickey mouse it if u dont know what ur doing, or if u want to save money jus by an amp kit for like $20 and u can buy a converter to change ur wires in to rca's ($15) and diy. well good luck with that
Image<--- MY CAR ALARM
562solara02
