SolaraGuy.com • View topic - Alternator
Alternator
Alternator
Postby 00-solara » Thu Jan 13, 2005 4:15 pm
I was wondering if a 10 L7 solobaric sub and a 400.1 kicker amp plus streetglow underbody LED would draw too much power for the stock alternator? Please help...
2000 Solara SE Diamond White Pearl: 4300K HIDs, Sony H/U, Infinity Kappa 60.5, 693.5i, Two Kicker CVX 10"
00-solara
Postby GR » Fri Jan 14, 2005 2:50 am
Not even close.
It is only around 400 Watts. We'll put 50W max on the LED, which adds to 450W. 450W/12V= 37 Amps. That might be difficult for the Echo, but the Camry/Solara is fine.
If in doubt you can always test the headlights at night and see if they're dimming.
More info:
http://www.zer0.info/solaraguy/viewtopic.php?t=2807
GR
Postby 00-solara » Sat Jan 15, 2005 9:25 am
Even with a new cd player and all new infintiy speakers it will be fine? Just making sure... :crazyeyes:
00-solara
Postby Jon11582 » Sat Jan 15, 2005 10:19 am
Solawra puts out 80A stock.
at 14.4V (car operating Voltage), thats 1152Watts going around. And thats continuous power.
Two biggest continuous draws of power:
Headlights = 110w
Foglights = 130w
Other stuff, maybe 200w total.
That gives you 700w continuous to play with.
Speakers and subs dont need continuous power, only on bassy hits, etc. when a hit takes more than the stock alternator can put out. your battery takes over the rest. Most batterys cant take a draw like that, and a telltale sign of you exceeding the alternator output is the headlights dimming on a bass hit.
Then you can get a capacitor to make up the rest, but at 400w, youll have no probs, even if the sub needed full power the whole time. Id say youd have to be over 1000w before even considering the stock alternator or the need of capacitors to be a problem.
2000 Black Solara SE
Jon11582
Postby Yanks0114 » Sat Jan 15, 2005 12:35 pm
I have 2 (1) farad and i think they are absolutely useless. If i were to do it all over again, i would have gotten the yellow top right away
you'll be fine with the setup you described
Postby B_Master_Flash » Mon Jan 17, 2005 5:38 pm
Yanks0114 wrote:I have 2 (1) farad and i think they are absolutely useless. If i were to do it all over again, i would have gotten the yellow top right away
A cap has about the same effect as taping a hundred dollar bill to your amp. A yellow top is good b/c it can quickly discharge and recharge w/o much damage to itself, but doesn't relieve any strain on the alternator.
And to answer your question, you will prolly experience very mild headlight dim at full draw which is nothing to worry about. I have a 1500wrms amp and my alternator hasn't given out yet.
B_Master_Flash
Postby MalBandito99 » Mon Jan 17, 2005 6:11 pm
I got same as you. Yellow top does help, I suppose, but at 1400 wrms amp with a 1600 wrms sub, I do get some dim, but I know for sure I cant be drawing that much power. maybe only 500-600 watts gets to the sub. And occasionally headlights dim when the bass hits (no foglights on) Anyone have experience on new alts for us with no extra installation required?
MalBandito99
Postby eugene5786 » Mon Jan 17, 2005 8:37 pm
I still got the 140amp alt for sale!
eugene5786
Postby HKSV6SLE » Mon Jan 17, 2005 10:15 pm
i ran my car with the a/c on full blast my radio on full blast....with my car running two RF he2's one 700S amp a alpine 4 channel amp head unti all after market speakers two 1 farad caps.. and a interstate megatron plus battery and i never came close to the alternator running out...... :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby ZXLNT » Mon Jan 17, 2005 10:37 pm
My car with 2 PPI2600's briged mono and a 200 watt full range amp kills my alternator. Major disco lights going on...
ZXLNT
Postby cam2Xrunner » Sat Jan 22, 2005 2:04 am
You guys ever hear of the "big 3"
http://forum.sounddomain.com/ubb/ultima ... 5;t=007801
If that doesn't stop your dimming problems then look into a high output alternator and a deep cycle battery (optima yellowtop/stinger)
Caps aren't the right way to fix the problem.
High output alternator thread
http://forum.sounddomain.com/ubb/ultima ... 5;t=006343
cam2Xrunner
Postby MalBandito99 » Sat Jan 22, 2005 9:15 am
trdcamry2003 wrote:You guys ever hear of the "big 3"
Yeah, but Im lazy!!! Id pay someone who knows how to do it right to do it for me. :P
MalBandito99
Postby cam2Xrunner » Sat Jan 22, 2005 3:37 pm
It's easy, you don't have to replace any wires you just add one alongside of them.
cam2Xrunner
Postby MalBandito99 » Sat Jan 22, 2005 11:11 pm
trdcamry2003 wrote:It's easy, you don't have to replace any wires you just add one alongside of them.
Neato! I looked at that DIY and it does indeed look like a can tackle it. Gona check it out next weekend.
MalBandito99
Postby cam2Xrunner » Mon Jan 24, 2005 5:05 am
Let me know how it worked out for you. Maybe post a new thread on it in the tutorials section.(don't know if anyone has done this yet)
cam2Xrunner
