SolaraGuy.com • View topic - Planet Audio Amps?
Planet Audio Amps?
Planet Audio Amps?
Postby sleepin2000 » Mon Jan 17, 2005 5:37 pm
I just recently bought a new sub (OZ Audio Matrix Elite Series 15") and now I need to find myself a bigger amp. I was thinking about a Planet Audio amp, has anyone had any expereinces with these or any suggestions on other brands?
In Memory of My Son
Christian Edward Goldstone
October 13, 2005 - June 7, 2007
sleepin2000
Re: Planet Audio Amps?
Postby jazzlara » Sun Jan 23, 2005 8:59 pm
sleepin2000 wrote:I just recently bought a new sub (OZ Audio Matrix Elite Series 15") and now I need to find myself a bigger amp. I was thinking about a Planet Audio amp, has anyone had any expereinces with these or any suggestions on other brands?
Make sure you get a mono channel amp if there is only one sub. ive had good experiences with kenwood, fosgate, eclipse, pioneer, mtx. If they are wired right and have enough juice to run them (without draining the battery and burning out the alternator), then you should have no problem with any good rated amp you decide to go with.
hope this helps
jazzlara
Postby cam2Xrunner » Mon Jan 24, 2005 5:10 am
Is the sub dual 2 ohm or dual 4 ohm? What is your budget? Are you going ported or sealed enclosure?
cam2Xrunner
Postby sleepin2000 » Mon Jan 24, 2005 6:14 pm
It has dual four ohm voice coils and it will be in a sealed box. As far as the budget goes, I don't really have a price range I'm looking at. I don't mind spending money if I feel it's worth it (quality, performance, etc...)
In Memory of My Son
sleepin2000
Postby pro956 » Mon Jan 24, 2005 8:36 pm
hope this helps
he doesn't have to get a mono channel amp, bad advice
class a/b 2 channel amps bridged can also provide better sq than a mono class d amp
AIM: pro956
2002 5-speed se v6
pro956
Postby pro956 » Mon Jan 24, 2005 8:42 pm
that's a really nice sq/sql subwoofer and you should definately give it some clean juice with something like a tru tech amp
AIM: pro956
2002 5-speed se v6
pro956
Postby cam2Xrunner » Mon Jan 24, 2005 10:29 pm
hope this helps
Agreed a class ab will give you better SQ.
Some good amps- DLS A6
Arc Audio 1500xxk
U.S.Amps usa-600
More affordable amps that will get the job done, just not as nicely as the above mentioned.
MTX 801.D
Hifonics brutus 1000D
JBLGTO601.1
The elemental designs nine.1 is an awesome amp too for only 350.00 shipped, 3 year warranty.
The OZ audio web site says the sub will take 700 watts rms, do you know if it can take more or not. Im sure it can, just getta keep the gains down on some of those amps listed.
cam2Xrunner
Users browsing this forum: No registered users and 2 guests
