SolaraGuy.com • View topic - Hiding those wires..
Postby FLASH » Thu Jan 27, 2005 3:07 pm
Hey guys, how do you all recommend to hide the wires under the carpet? like..where are the best places to run them?
Pictures would help a million. Thanks all
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Re: Hiding those wires..
Postby pro956 » Thu Jan 27, 2005 3:35 pm
FLASH wrote:Hey guys, how do you all recommend to hide the wires under the carpet? like..where are the best places to run them?
yeah under the carpet.
run them down the sides of your car-- near the doors, the panels are easy to pull off, run it all the way down and up under your back seats and into the trunk...
AIM: pro956
2002 5-speed se v6
pro956
Postby FLASH » Thu Jan 27, 2005 8:05 pm
NO need to unbolt the seat? just run them under the plasteic frames,etc?
==FLASH==
FLASH
Postby trdkamuri51o » Thu Jan 27, 2005 9:10 pm
yep
trdkamuri51o
Postby Mole » Thu Jan 27, 2005 11:55 pm
if you want to do a 81887 job of hiding the wires, i suggest you go under the carpet right down the middle of the car.
that would take some time though.
Postby SleeperSolara » Fri Jan 28, 2005 8:29 am
RCA wires, or power wire??
Remember to keep them apart.
If you have long RCA wires run them down the middles or through the passenger door side kick panel.
Postby pro956 » Fri Jan 28, 2005 8:39 am
SleeperSolara wrote:RCA wires, or power wire??
you can send the rca's down one side and the power down the other side...
AIM: pro956
2002 5-speed se v6
pro956
Postby SleeperSolara » Mon Jan 31, 2005 8:27 am
Yeah if you have long enough RCA wires.
Of course Power wire down the driver kick door panel.
Gound wire; when i had a system back in the day i just bolted the gound to the seat in the back, just pick the closest bolt on the seat as a groundin' point.
