SolaraGuy.com • View topic - Stock JBL Specs
Stock JBL Specs
Stock JBL Specs
Postby bparker » Sun Jan 30, 2005 7:37 pm
I have an '02 SE V6 with JBL, and I'm trying to find the stock stereo specs so I can simply replace the stock speakers, I'm thinking of going with infinity kappa, or the reference series. What size speakers will work out-of-the-box in our cars, without any modifications? Also what are the specs of the speakers and the amp? RMS power/etc. I want to know how much the amp will put out so I don't waste money on speakers that the stock amp won't be able to take advantage of, or should I replace the amp? Thanks for all input.
bparker
Postby Jackass-Jeff » Mon Jan 31, 2005 11:52 am
You're better off upgrading the headunit first and bypassing the stock amp. The stock amp is rated at 200 peak and is not as good as a stock headunit (well, assuming you get a good brand).
The stock amp is located next to the ECU behind the glove box. Simply remove the glove box and you'll see the ECU (looks like a giant old school harddrive... 5.25") and the JBL amp (ribbed like a heatsink).
The JBL speakers have some decent power handling but need some cleaner mid-bass.
Front 6.5" , rear 6x9 (although you can put a bracket in and put in 6.5 and tweeters in the rear).
1GR-FE ftw!
Jackass-Jeff
