SolaraGuy.com • View topic - Diagram or Pic of the back of the 2004 head unit
Postby mmcdonald » Tue Feb 01, 2005 10:45 am
Folks,
One last shot at installing the Sirius radio myself...
I can get the lower bin off, and the center console with no problem, but I can't get the guage pod off over the radio, so the head unit is not coming out. I can feel the connectors back there, but don't know what kind they are or what goes where. I have a left and right mini RCA from the Sirius unit, but don't know what adapters I need or where they plug in.
DOES ANYONE HAVE A PIC OF THE BACK OF THE HEAD UNIT, or a diagram? I could get it together if I just knew where things went. Otherwise it's down to Best Buy to pay for it to be installed.
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
Postby cklinh » Tue Feb 01, 2005 11:09 am
for the gauge pod, just give a good yank (towards the back of the car)... i had a grip of the little overhang thing on top of the gauges... was actually quite easy... removing the harnesses behind it was another story... i just left them in and turned the gauge pod upside down and laid it on the dash while I did my work.
cklinh
Yank it, huh?
Postby mmcdonald » Wed Feb 02, 2005 7:19 am
I had my fingers on it, I just couldn't bring myself to pry or yank it any further. I could even see the clips. Dang.
Well, when you got your head unit off, what did the back look like? What kind of connectors? Where would I hook up the stereo in?
Thanks
XM Tuner DIY
mmcdonald
Postby cklinh » Wed Feb 02, 2005 9:17 am
I have the Navi... it'll be different from yours...
cklinh
Postby Astro » Wed Feb 02, 2005 10:34 am
Try this:
toyotaparts4u satellite radio instuctions (pdf file)
Also, check out SiennaClub they have some cool ideas with the Solara navi.
Thanks
Postby mmcdonald » Thu Feb 03, 2005 6:10 am
I am checking out the BlitzSafe adapter. That should be a big help. I am assuming that only plugs in one way.
The adapter is for non-Nav units.
I have a similar version of the installation instructions, but there is still no diagram of the back of the unit, or any specs on the connectors used even. It just says "disconnect the connectors," and "reconnect the connectors." :-?
XM Tuner DIY
mmcdonald
