SolaraGuy.com • View topic - Help installing Navigation system (Speed & Reverse Senso
Postby Grant516 » Tue Feb 01, 2005 2:32 pm
Good Afternoon Everyone,
little trouble today.
I'm putting in a Kenwood Excelon DVA-4100 Navigation system into my car and I Need first to connect it to the
Speed Sensor in my car
and the
Reverse Sensor
Anyone know where I might find those two wires?
I've heard rumors of steering columns and the ECU.
Any one have any experience with this?
Much appreciation! I'll post some pics of the DVD player/Navigation when its all finished.
hopefully i'll get my car washed up too from this nasty ny winter. :oops:
Grant516
Postby Grant516 » Wed Feb 02, 2005 9:24 am
nobody knows this?
Grant516
Postby Turbosolara » Wed Feb 02, 2005 9:27 am
I4 or V6? I am sure there is a wire on the ecu is for the speed sensor, you can have someone pin it out for you. The reverse wire usually is by transmission.
Postby eyedea » Wed Feb 02, 2005 9:47 am
look at this post by yanks*
http://www.zer0.info/solaraguy/viewtopic.php?t=11665&highlight=
then look at his webshots links. There under nav install is a pic showing which wire, what where ...blah
any questions..directed to him. Glad to be of help
5SP 02 SE V6 SC 1MZFE .......RIP ...
2003 Infiniti M45 =340hp of RWD sex
eyedea
Postby Astro » Wed Feb 02, 2005 10:57 am
This is something from siennaclub.com, this was actually installing a Solara nav into a Sienna. But, it looks like it could be behind the glove.
Before installing the new nav unit you’ll need to run wires for the two sensors. The R9 connector on the back of the new NAV system needs to be supplied with speed sensor input and from the reverse sensor. The folks at oemvalue were good enough to supply this connector. The wire located on the far left (wire #5) is to be connected to the reverse/neutral (REV) switch. The wire in the center (wire #3) is to be connected to the vehicle speed sensor (VSS). I found it very easy to make these connections by removing the lower glove box. Just to the left of the glove box opening is a small harness consisting of 5 wires. The are attached to a metal bracket via a cable tie and must be cut in order to get some slack to work with. They are also wrapped in a rubber type insulation which can be carefully snipped off with scissors. Inside this bundle you’ll find two wires. One is violet (purple) and white stripe for the VSS. The other is red with a black stripe which is for the REV sensor. These wires are very small and fragile (24 gauge) so be extremely careful when making these connections. It’s best to use a “tap-in” style connector because it doesn’t require you to not cut the original wire but yet splice into it with another wire and continue the connection to the nav unit. I used 22 gauge radar detector wire and ran it up to the opening for the nav unit. At this point you can make the connection to the VSS/REV connector that came with your unit. Again, you can use the same connectors or a butt style connector if you so choose.
Postby Yanks0114 » Wed Feb 02, 2005 6:31 pm
the vss is a pink wire on the ECU - look at my pictures for the location
The reverse lead needs to connect to the taillight bulb. On mine i think it was to the positive lead on the reverse.
Hope this helps
Postby Grant516 » Wed Feb 02, 2005 6:45 pm
Astro wrote:This is something from siennaclub.com, this was actually installing a Solara nav into a Sienna. But, it looks like it could be behind the glove.
They are also wrapped in a rubber type insulation which can be carefully snipped off with scissors. Inside this bundle you’ll find two wires. One is violet (purple) and white stripe for the VSS. The other is red with a black stripe which is for the REV sensor. T.
I took a look at pictures, color codes are uniform for same year Toyotas right? So if the solara has a Red wire with black stripe that in the ECU that means I dont have to tap all the way back to the reverse lights, right?
Thanks everyone for all the help, i'll have the DDX7015-and DVA-4100 up and running smooth in no time.
Grant516
Postby Yanks0114 » Thu Feb 03, 2005 12:32 am
well thats off a sienna, so i'm not sure about the reverse signal wire
It was pretty simple to tap into the tail light. The manual should tell you if you need a + or - lead, and then just use a digital multi-meter to figure out which is which
Good luck on your project
Postby Arthur2k4 » Thu Feb 03, 2005 12:56 am
sienna club? wtf? theres mini van clubs though...wow
Arthur2k4
Postby Parke10 » Thu Feb 03, 2005 1:38 am
some of those vans are nic,for vans at least and they do have the same S/C and engine as the solara so they run good ( atleast i think they have the same stuff)
Parke10
Postby Grant516 » Thu Feb 03, 2005 11:43 am
boy getting that glove compartment off is a FemmeDog.
Grant516
Postby Yanks0114 » Thu Feb 03, 2005 5:00 pm
Grant516 wrote:boy getting that glove compartment off is a FemmeDog.
It shouldn't be hard. In my pics i have a basic tutorial on how to remove it
Postby Grant516 » Fri Feb 04, 2005 10:43 pm
the red wire with black stripe IS a reverse sensor.
everything is installed and running.
I appreciate the help very much.
Grant516
