SolaraGuy.com • View topic - Heres my planned system any feedback
Postby Eviltwinpsu » Sun Feb 20, 2005 9:41 pm
Heres what i am looking to buy to put into my car.....
Head Unit:
referbished Kenwood eXcelon KVT-915DVD
http://www.salectronics.com/detail.asp? ... VT915DVDRB
with
Kenwood KNA-DV4100 nav
http://www.dynamixcaraudio.com//index.a ... ProdID=648
Center channel
Alpine SBS-0715 and going to instal it in that compartment under the seat warmers
http://www.crutchfield.com/S-yi4T0R96PI ... 500SBS0715
my other option is the Clarion SRK5 1/2-DIN Center Channel Speaker
but someone said that it just doesn't sound good
http://www.etronics.com/product.asp?ica ... svbname=16
sub
JL Audio 13w7
http://www.radiomancaraudio.com/jl-audio-subwoofers.htm
speakers
4 of Infinity Kappa 693.5i 6"x9" 3-way Speakers
http://www.hookedontronics.com/show_pro ... ppa+693.5i
amps
ROCKFORD FOSGATE Power T15002 Car amplifier 2 channel
http://www.hookedontronics.com/show_pro ... wer+T15002
to run the subs
and maybe if i can....AUDIOBAHN A4004T 4 channel car amplifier
http://www.hookedontronics.com/show_pro ... ahn_A4004T
any input into what you guys think....btw going to have someone professional install all this stuff
Eviltwinpsu
Postby Jackass-Jeff » Sun Feb 20, 2005 10:47 pm
it looks like you're going all out... don't get 3 way speakers-- get true components. You won't regret it!
1GR-FE ftw!
Jackass-Jeff
Postby Aotoyota » Mon Feb 21, 2005 9:09 am
you may have trouble with the alpine center channel, its a single din openeing and i know for a fact that in the lower pocket on the dash, it cant fit. plus if you look dead on, its tapered. meaning that to make it fit there is gonna take some work and cutting.
and components will sound lots better than a three way.
Aotoyota
Postby cam2Xrunner » Mon Feb 21, 2005 10:27 am
IMO i'd skip on the kenwood headunits and nav unit and get an all in one unit like the Pioneer Avic n1 or the Eclipse AVN2454. Both can be had for around 1500 bucks. For the Eclipse I know where to get them for 1600.00
I would definitely look into a set of components as compared to a three way speaker. I'd rec. instead of buying the 4 kappa speakers and the center channel speakers to use that same money on a set of high end component speakers for the fronts. IF you also want rear fill then get a 2 way kappa for the rear.
Theres also alot better amps then Rockford fosgate for the money, and just plain stay away from audiobahn stuff if you are serious about car stereo stuff.
What's your budget for everything and if you like I'll try to point you in the right direction.
cam2Xrunner
Postby Eviltwinpsu » Mon Feb 21, 2005 8:27 pm
cam2Xrunner wrote:IMO i'd skip on the kenwood headunits and nav unit and get an all in one unit like the Pioneer Avic n1 or the Eclipse AVN2454. Both can be had for around 1500 bucks. For the Eclipse I know where to get them for 1600.00
well im very new to audio....i chose the kenwood because i was looking for a single din that was sirius ready
was thinking of 2k for both the nav/915dvd
and i can go from 1k-2k for the rest
any suggestions will be apreciated...i
Eviltwinpsu
