SolaraGuy.com • View topic - cable length
cable length
cable length
Postby bparker » Wed Mar 16, 2005 1:02 pm
What length of cable is needed to run from the battery to the trunk and from the headunit to the trunk?
bparker
Re: cable length
Postby cam2Xrunner » Thu Mar 17, 2005 8:12 pm
bparker wrote:What length of cable is needed to run from the battery to the trunk and from the headunit to the trunk?
From the battery to the trunk I would guess about 20 ft. Maybe less. I would order about 30 ft, so you'd have enough to do the ground wire for the amp, as well as the BIG 3 upgrade.
As far as headunit to the trunk, depends.
If you are going to run RCA's to the trunk through the center console and to the trunk you'd probably need about 12 ft. But if you are running them from the headunit and under the dash, then along the side of the car and into the trunk you might need something around 18 ft.
Use some yarn or string and pretend you're wiring it with the string. Then measure the amount of string you used.
Big 3 info
http://forum.sounddomain.com/ubb/ultima ... 5;t=007801
Good place to buy wiring
www.knukonceptz.com
cam2Xrunner
