SolaraGuy.com • View topic - speaker amp wiring/location
Postby bparker » Thu Mar 17, 2005 2:40 pm
I'm kindof stuck here. I was thinking about getting a 4-channel Infinity Reference amp for my speakers, it does 111Wx4 RMS at 4 ohms, but according to crutchfield it requires 8awg wire. So I went over to the12volt.com and it says you cannot run 400watts on 8awg over 8 feet, but
8awg is required to hook up to the amp, and the only place I can think of to
put the speaker amp is in the trunk with my sub amp, which is too far for that wattage and gauge wire. Any ideas/suggestions for placement/wiring of this setup? Thanks a lot.
bparker
Postby cam2Xrunner » Thu Mar 17, 2005 6:42 pm
Use 4 gauge.
cam2Xrunner
Postby bparker » Thu Mar 17, 2005 8:22 pm
I thought that because the webpage says it requires 8 gauge is because that is the size of the connector, nothing else would fit it, especially any bigger sizes.
bparker
Postby ZXLNT » Fri Mar 18, 2005 11:25 pm
If need be they make a step down adapter to go from 4ga to 8ga. Its just a small metal piece with 4 ga hole and 8 ga pin that goes into amp. Depending on how large ur amplifier is if may mount under the front pass seat. Thats where mine is at..
ZXLNT
Postby bparker » Sat Mar 19, 2005 10:21 pm
I ended up just running a distribution block. 4ga in, 4ga out and 8ga out. Also I'm only going to be using 2 channels for the speakers so the wattage/current should not exceed what's allowed for 4ga at the range I'm using.
bparker
Postby ZXLNT » Sat Mar 19, 2005 10:28 pm
You'll be good up to several hundred watts. What speakers are u going to power??
ZXLNT
