SolaraGuy.com • View topic - Amp mounting/pics
Amp mounting/pics
Amp mounting/pics
Postby bparker » Sun Mar 20, 2005 9:27 am
Can anyone supply pics or instructions on how to mount two amps in our cars (I have an 02 se v6)? Thanks.
bparker
Postby cam2Xrunner » Sun Mar 20, 2005 7:53 pm
http://www.toyotanation.com/forum/showt ... adid=13159
http://www.bcae1.com/amplfier.htm (scroll down like 3/4 of the way down)
To power two amps, you are going to use a distrubution block.
http://www.knukonceptz.com/productDetai ... ID=BC-1428
Run 4 gauge fromt the battery to an inline fuse holder like this one
http://www.knukonceptz.com/productDetai ... odID=FH-24
Then run 4 gauge wire from the inline fuse holder, through the rubber grommet in the firewall, near the master cylinder. from the inside of the firewall, run the power wire under the carpet. You can run it alongside the door sills, then under the back seat into the trunk. Once the power wire is routed to the trunk. Use the distribution block to separate the power to 2 8 gauge power wires, each one to an amp.
If you are going with a high power system 150 Watts RMS x2 for the components and 500 + watts rms for the sub, then you might want to go with 0/1 gauge power wire from the battery to the inline fuse holder. You'll need a larger ANL fuse inline fuse holder like this one.
http://www.knukonceptz.com/productDetai ... -20B%20ANL
You'll also need a 0/1 gauge to (2) 4 gauge. Like this one.
http://www.knukonceptz.com/productDetai ... D=FB-1024D
Use 4 gauge for the ground wire on each amp.
When mounting the box make sure you are mounting it to a panel of MDF wood. 3/4" preffered if possible. You can make a false floor to house the two amplifiers and have a built in cooling system. This is a whole nother thread for this.
The easiest way to do it is to get a sheet of 3/4" MDF wood and make a panel that will hold the two amps. Then get some L mounting brackets to secure it to the floor of the trunk.
cam2Xrunner
Postby bparker » Sun Mar 20, 2005 8:45 pm
I already have everything wired up and working (and yes I used a dist. block and ANL fuses), but my two amps are just sitting in the trunk as I have no simple way to mount them anywhere. Do you (or anyone) have a link or instructions on simply mounting the amps? Thanks.
bparker
Postby Duffman » Mon Mar 21, 2005 6:13 am
I mounted my amp and my CD changer on the back seats. Make sure the fins on it will let air flow over it and you should be okay.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby bparker » Mon Mar 21, 2005 10:28 am
There's no room to mount my amps on the backseat, there's these stupid locks right in the middle of both seats and there's no other part of the seat to mount it to that will allow them to still be folded down. Any suggestions?
bparker
Postby Duffman » Mon Mar 21, 2005 11:46 am
How good are you with a jigsaw?
You could get some wood (MDF or good solid plywood) and cut a piece that'll give you a custom fit somewhere. I'll admit, for the longest time mine just sat in the corner, loose. Maybe get a box that has room on it for mounting amps?
http://www.crutchfield.com/S-bWAlTo9rFoG/cgi-bin/ProdView.asp?g=178650&I=044UHC112
Duffman
