SolaraGuy.com • View topic - Sound Dampening
Sound Dampening
Sound Dampening
Postby frohboy33 » Thu Mar 31, 2005 7:17 am
I was just wondering, for you people who have done some sound dampening in your car, how much it cuts down on the road noise. I don't really plan on doing it to make my sound system better, but more for the road noise. So I was wondering if you guys think it would be worth it. Thanks for your replies.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby SleeperSolara » Thu Mar 31, 2005 8:24 am
It would be worth it man.
It does both, cut out road noise and makes your system sound better and clearer.
It also depends on how you apply the stuff too.
Postby Yanks0114 » Thu Mar 31, 2005 9:30 pm
I disagree sleeper. I think most people do the trunk only, or the trunk and sometimes the doors.
I won't do much to lessen road noise unless you do the floor which would involve removing the seats and the carpeting.
Not worth it just to lower road noise
Postby cam2Xrunner » Fri Apr 01, 2005 12:44 am
The matting with raammat/edead/Dynamat,etc doesn't do much for road noise. It does stop the panels from resonating and vibrating, which can cause unwanted noise in the car. Also matting makes the doors and trunk flex less which gives your midbass/subs have a tighter sound to it.
For blocking road noise you need to use a type of foam or padding like ensolite or carpet padding. The foam/padding will block some of the road noise.
Here's some good reading....
http://www.toyotanation.com/forum/t64909.html
http://secondskinaudio.com/forums/
cam2Xrunner
Postby Mole » Fri Apr 01, 2005 1:31 am
Might I add it will get costly if you do the entire car... (or as much as possible.)
Postby cam2Xrunner » Fri Apr 01, 2005 2:22 am
Mole wrote:Might I add it will get costly if you do the entire car... (or as much as possible.)
And add a bit of weight. I could feel the difference in my camry which was completely done.
The best value in dampening is the edead v1.se. Make sure to use the 20% off coupon code I posted in that first link.
The edead v1.se is 70 mils. thick. Fatmat, b quiet, dynamat, second skin, etc. is all 45 mils thick. Rammat60BXT is now a little thinner than the old Rammat60, which was 60 mils thick.
2 layers of v1.se is like 3 layers of the other brands.
cam2Xrunner
Postby dvdchris45 » Fri Apr 01, 2005 2:26 am
From what I've heard you can get Dynamat sheets/roll for $90 for 200 SQ FT. This is an extremely excessive amount of Dynamat when on average you'll dynamat no more than 30 sq ft for your entire car. I'll look into it.
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby frohboy33 » Fri Apr 01, 2005 7:47 am
You'll definately use more than 30 sq feet. That isn't that much considering you'll probably doulble up in some areas. I would say your gonna use close to 100+ sq feet.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby cam2Xrunner » Fri Apr 01, 2005 7:59 am
dvdchris45 wrote:From what I've heard you can get Dynamat sheets/roll for $90 for 200 SQ FT. This is an extremely excessive amount of Dynamat when on average you'll dynamat no more than 30 sq ft for your entire car. I'll look into it.
I use more than 30 sq ft on my front doors.
Dynamat is usually much more expensive than that, and the regular dynamat sucks. I would only use Dynamat Extreme, and that's way more then eDead v1.se/
cam2Xrunner
Postby frohboy33 » Fri Apr 01, 2005 12:05 pm
Hey do you know how to take out the back seats in the solara. I have never bothered looking at them to see how to take them out. Is it tough?
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby krook » Fri Apr 01, 2005 4:58 pm
taking out the back seats suck. you have to pretty much remove the bottom seat cushion, the belts, and the rear deck. and the rear panels too! 10mm bolts for the rear deck, 15mm for the seats, and 12mm for other bolts if i remember correctly.
krook
Postby DirtyRoach » Thu Apr 14, 2005 9:29 pm
Has anyone used quietcar before?
www.quietcar.net
I'm thinking about doing my trunk with it. The audio examples sound pretty good.
I did my last car in brownbread. 2 to 3 layers in the trunk. Totaled it before I could get my system in though. I think spraying it would be much quicker/better than laying the sheets.
2k SE V6 5spd. Blk on Blk leather. HIDs
So many mods, so little time, even less money!
DirtyRoach
Postby cam2Xrunner » Sun Apr 17, 2005 8:07 pm
DirtyRoach wrote:Has anyone used quietcar before?
www.quietcar.net
I found the same thing for WAY cheaper...
www.mcmaster.com
Go to page 3274
They sell the 5 gallon bucket for 68.95 compared to the 239$ bucket at quietcar :drinking:
cam2Xrunner
Postby DirtyRoach » Mon Apr 25, 2005 11:40 am
www.quietcar.net
www.mcmaster.com
Go to page 3274
Good find. I ended up purchasing it at quietcar before I saw your reply. Maybe the more expensive stuff will be a little better. 5 gals for 68.95 sounds almost too good to be true. The quietcar is still much cheaper than laying the other stuff down.
DirtyRoach
Postby cam2Xrunner » Mon Apr 25, 2005 12:14 pm
Actually after doing some searching, it looks like the stuff I linked isn't the best thing to go with. I hear it's too thick and it shrinks down to almost nothing.
cam2Xrunner
