SolaraGuy.com • View topic - Will these speakers fit into my 2000 SE solara
Postby Strider327 » Wed May 04, 2005 7:45 pm
http://www.goodguys.com/adtemplate.asp? ... tky=207135
I would just like to know if they do, I had these in my 1994 camry and fitted with no problem...and these right here:
http://www.bestbuy.com/site/olspage.jsp ... 9388426059
Thanks for any advice,
Calvin
Strider327
Postby indiglosolara » Wed May 04, 2005 7:55 pm
they can.... but if your looking for better sound in the front why not go with a set of components..
its not that much more then the ones you have listed..
go with some infinite, jl audio, or even mb quartz... that are about 150 for a set for the basic models...
i got my Jl audio for about $225.00 shipped..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Strider327 » Wed May 04, 2005 9:13 pm
Well thing is I already have them...haha dun want them to go to waste. Second broke as a joke and paying off the solara as we speak.
Strider327
Postby SleeperSolara » Thu May 05, 2005 7:07 am
Yeah they will work man.
Just be sure if you use the stock mountin' brackets to secure the speaker to the bracket good.
It would be better if you make some MDF brackets though.
I have some Alipne Type S, and they sound awesome, but my rear passenger is startin' to rattle caues i didn't secure the speaker down good, now i got to make some MDF brackets for them.
Postby trdkamuri51o » Thu May 05, 2005 6:34 pm
hahaha so u got one???
DETAILS DUDE@!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
trdkamuri51o
Postby cdeez » Thu May 05, 2005 10:49 pm
indiglosolara wrote:they can.... but if your looking for better sound in the front why not go with a set of components..
components are always the best way to go when upgrading highs.....
last standing...
Socalara...
cdeez
Postby Duffman » Fri May 06, 2005 6:13 am
6x9 will work in the back, and if you really want to, you can use the stock basket (minus the speaker, duh) and just screw into the bracket... your best bet is to get a baffle and mount directly to the metal (with the baffle being between the speaker and metal). The back speakers are a pain to get to though, so I'd suggest just getting your high-end "happy speakers" you really want when you decide to put them in. The fronts are 5 3/4", and they're easy to get to, and you can use the stock mounts as long as you cut/dremel the little piece on it that holds the wire mount.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby SpeedSTARs » Sat May 07, 2005 12:59 am
Most definitly... If used for the front channel, they will bring a richer sound stage. And yes Strider327, they fit perfectly in the front doors and rear chimsel (rear deck). Good luck on your project. :wink:
-G :turn-l: :turn-l: D guy..
SpeedSTARs
Postby Strider327 » Sat May 07, 2005 1:13 am
thanks for all the feedback I appreciate it. I will definitely get them installed this weekend, along with my trd sway bar.
Strider327
Postby SpeedSTARs » Sat May 07, 2005 6:19 pm
Strider327 wrote:thanks for all the feedback I appreciate it. I will definitely get them installed this weekend, along with my trd sway bar.
Hey Strider327... When you get that sway-bar installed, Make sure you have the technician lube the polyurethane bushings with either lithium grease or synthetic grease. You'll thank yourself for doing so. :D Doing this will eliminate future squeaking in the rear suspension. Good luck.
SpeedSTARs
Postby B_Master_Flash » Sun May 08, 2005 7:55 pm
comps > coaxials. Those x9s will work in the back, but upgrading the front speakers should be your first priority.
B_Master_Flash
