SolaraGuy.com • View topic - jl audio
jl audio
jl audio
Postby ptorican-king » Tue May 10, 2005 5:27 pm
sup guys
my brother just got 3 12 inch jl audio subs ( dont know exactly any other info i think they are the basic ones )
anyway question is his running a 600 watt amp and wants to know what guage wiring he should get.
also what is your opinion on jl audio subs
well guys once again thanks in advance
LUIS
1999 SLE Green stock SOLARA
ptorican-king
Postby bassthrive » Tue May 10, 2005 7:29 pm
for 600 rms i would go no lighter than 4ga.
http://www.the12volt.com/info/recwirsz.asp
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Re: jl audio
Postby SpeedSTARs » Tue May 10, 2005 7:55 pm
ptorican-king wrote:sup guys
LUIS
SUP guy,
I have a pair of DVC W3 12's, and I must say they rock. The bass has a very smooth roll off... Which model is you brother running? Anyway, here is chart from the JL Audio site that specifies the RMS (continues Wattage) recommendations. As listed in the chart, just verify which model you are running and just run them in the yellow range. Just remember, that it also depends on how you wire them up (in series or in parallel) and if your going to run them in 8ohms or 4ohm's loades. I hope this chart serves you well. :angel:
Here you go:http://www.jlaudio.com/subwoofers/pdfs/SUB_PowerRange.pdf
-G :turn-l: :turn-l: D guys
SpeedSTARs
Postby SleeperSolara » Wed May 11, 2005 7:21 am
600 watt should be about 4 gauge or 2 or 1/0 gauge.
2 might be better of you runnin' to multi amps.
