SolaraGuy.com • View topic - Pexiglass??
Pexiglass??
Pexiglass??
Postby SleeperSolara » Wed May 11, 2005 7:49 am
Would makein' a ported box wit all Pexiglass be as strong as MDF or fiberglass??
I was wonderin' about it, and what would you cut pexiglass wit for the right size??
Re: Pexiglass??
Postby SpeedSTARs » Wed May 11, 2005 3:06 pm
SleeperSolara wrote:Would makein' a ported box wit all Pexiglass be as strong as MDF or fiberglass??
Plexiglass is hard to work with. Just in the case of your application, the plexiglass would have a hard time sealing the box. The vibrations from the subs will probably rattle the fastener loose; however, it sure looks nice... I think the MDF will hold better or even a custom fiber glass mold will do the trick. Good luck with you project. :) :) :)
SpeedSTARs
Re: Pexiglass??
Postby B_Master_Flash » Wed May 11, 2005 3:18 pm
1/2" Plexi is strong enough. When I make boxes w/ Plexi glass I've always made them MDF/Plexi Combo. Just try to hide your screws and seal w/ Silicone, Liquid Nails wont bond to plexi right. I dont know if its recommended (and I dont care) but I've always cut plexi w/ my table saw
B_Master_Flash
Postby Jai_Jai_Binks » Thu May 12, 2005 7:59 am
^^ what he said..plexi comes in different thickness/strengths, so choose somthing you can diy cut with your tools and if you make custom cuts, get somthing you can sand and smooth!
(off topic: by i made a diy kitchen splash guard by using plexiglass by using a glue meant to stick to walls and then i screwed the plexi glass in corners, that thing is still up, and looks good!)
Postby SleeperSolara » Thu May 12, 2005 8:05 am
I wanted to know if it was possible to make a ported wit pexiglass.
I was goin to get it from cardomain.
http://www.cardomain.com/item/CARPLC3416
This is 3/4" pexiglass, is it as heavy as 3/4" MDF??
Where can i get some pexiglass besides cardomain.
Postby B_Master_Flash » Thu May 12, 2005 1:13 pm
SleeperSolara wrote:I wanted to know if it was possible to make a ported wit pexiglass.
Am I reading that right?
If you're asking what I think you're asking, then of course. Why wouldn't it be?
B_Master_Flash
Postby SleeperSolara » Thu May 12, 2005 4:57 pm
B_Master_Flash wrote:Am I reading that right?
Well i was wonderin' if it is as strong as 3/4" MDF ported box.
I just checked Home Depot about pexiglass and they don't have 1/2" thick pexiglass.
Where can i find thicker pexiglass??
Would a full ported pexiglass box be as heavy as a 3/4" MDF ported box.
