SolaraGuy.com • View topic - head unit problem need help ASAP
Postby ptorican-king » Wed May 11, 2005 1:14 pm
ok i got what i consider a big problem
i take my car to the stereo shop ( in germany ) to install my aftermarket head unit. i think they couldnt find a wiring harness that fit so the cut :evil: the wires form the harness that plugs into the back of the factory head unit. my problem is now the aftermarket head unit dont work,, i think they where going to install it wire by wire. and now i cant put the factory head unit back on cuz theres no way to plug the cables back into the harness
what other toyota vehicle factory units are the same as ours that maybe i can get the factory harness from or any other solutions you guys can offer i cant survive without music :cry:
thanks LUIS
1999 SLE Green stock SOLARA
ptorican-king
Postby cam2Xrunner » Wed May 11, 2005 2:01 pm
Did the cd player ever work? I think what they did was wire the cd player into the factory amp. Which is not good.
What kind of CD player do you have now? If the CD player is still good what I would do is re-install it, following the info on this thread to bypass the factory amp.
http://www.solaraguy.org/viewtopic.php?t=15629
Get those wiring adapters in the link's. You can get them from most stores, but if you can't find one, see if Crutchfield will ship it.
[/url]
cam2Xrunner
Postby ptorican-king » Wed May 11, 2005 10:17 pm
cam2Xrunner once again thanks
it was 5:30 am in germany when i read this and at that time i walk downstairs and finish the job yes the stupid MOFO was trying to connect the aftermarket head unit to the factory amp that is why the wiring harness didnt work
thanks
LUIS
ptorican-king
Postby cam2Xrunner » Fri May 13, 2005 1:43 am
ptorican-king wrote:cam2Xrunner once again thanks
thanks
LUIS
Awesome. So I take it you got it to work right?
cam2Xrunner
Postby ptorican-king » Fri May 13, 2005 10:46 am
yes i did eveything is up and running dumd german
now im trying to get my money that i pay for the install since i ended up doing it myself
ptorican-king
