SolaraGuy.com • View topic - speaker amp keeps blowing
Postby bparker » Thu Jun 09, 2005 4:55 pm
I have an Infinity Reference speaker amp (97Wx2) that I'm using for my Type-R components in the front, and yesterday it blew the fuse. No big deal I think, so I disconnect the ground and replace the fuse, then the second I reconnect the ground, it blows the brand new fuse. I tried removing the power from my sub amp also, that didn't help, all I managed to do was consecutively blow 5 30A fuses. Any ideas? Is it likely that the speaker amp is somehow broken now? Any help is greatly appreciated.
bparker
Postby ZXLNT » Sun Jun 12, 2005 9:09 pm
Probably something shorted internally in the amplifer. Either output transistors in the audio section or maybe rectifier diodes in the power supply.
ZXLNT
Postby B_Master_Flash » Sun Jun 19, 2005 5:11 pm
Did the amp ever work? That usualy happens when you plug the pos and ground wires in the wrong slots. If they're in there correctly you prolly have a short.
B_Master_Flash
