SolaraGuy.com • View topic - HELP!!! Amp Placement???
Postby WJN333 » Fri Jun 24, 2005 3:36 pm
Ok so Ive removed all the seats, and im trying to mount the amp for the sub. I dont think it will fit under one of the front seats with those a/c vents there. It seems too exposed on the back of the back seats and blocks the lever to open them from inside the trunk? upside down on the deck that hold the rear speakers, dosen't seem like a viable option?
Little help...PLEASE! :lol:
WJN333
Postby bassthrive » Fri Jun 24, 2005 4:12 pm
if you dont mind losing your spare you could always...
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby WJN333 » Fri Jun 24, 2005 4:59 pm
LOL gotta keep the spare. I think we might have the same amp, similar at least. When i run the power can i put the fuse on the amp side of the cable, or does it have to be near the batt? Thanks
WJN333
Postby WJN333 » Fri Jun 24, 2005 7:46 pm
Looks like im stuck with the back of the back seat. No prob, should be in tonight.
WJN333
Postby WJN333 » Fri Jun 24, 2005 9:15 pm
How did you get around the air duct?
WJN333
Postby cam2Xrunner » Fri Jun 24, 2005 11:15 pm
Mount it to the back of the back seat. Vertical.
cam2Xrunner
Postby ZXLNT » Fri Jun 24, 2005 11:38 pm
I have my PPI PC2600's mounted in the wheel wells on each side of the trunk..
ZXLNT
Postby ZXLNT » Fri Jun 24, 2005 11:43 pm
ZXLNT
Postby ZXLNT » Fri Jun 24, 2005 11:44 pm
ZXLNT
Postby WJN333 » Sat Jun 25, 2005 12:23 am
ZXLNT
I like what you did there. Unfortunatly, i dont have custom work back there that you do.
Looks like that rear of the back seat is my best option.
Thanks for all the input all.
WJN333
Postby bassthrive » Sat Jun 25, 2005 9:50 am
WJN333 wrote:LOL gotta keep the spare. I think we might have the same amp, similar at least. When i run the power can i put the fuse on the amp side of the cable, or does it have to be near the batt? Thanks
Its a KAC-8101D. You're gonna want to put the fuse close to the battery. Mine is approx 1 foot downstream of the positive terminal.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby BradOwens » Sat Jun 25, 2005 9:58 am
ive got mine mounted to the top of the trunk. it is mounted on a piece of wood covered in trunk cloth.
BradOwens
Postby Paladin06Greg » Sat Jun 25, 2005 10:24 am
How is it going to breath. With almost no air flow your amp will have a very short life and high heat can cause poor sound quality as well. Here is where I put both of mine.
Love that chrome and blue neon stuff.
bassthrive wrote:if you dont mind losing your spare you could always...
Paladin06Greg
Torqued Solara
Torqued Solara
Postby bassthrive » Sat Jun 25, 2005 12:15 pm
No heat issues here greg. The amp never gets warmer than when I had it exposed, even on the hottest days that area stays nice and cool. I may worry a little if I were pushing more than just 200w.
How are you running your sub? I see a board where you screwed your amps in but is the speaker free-air or is there some sort of box extending into your back seats that I'm not seeing? I'm diggin the chrome.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
