SolaraGuy.com • View topic - Creating housing for trunk subwoofers
Postby thatdamngood777 » Sat Jul 09, 2005 5:11 am
Does anyone know a good site to go to that has information on how to build a housing for subwoofers, amplifiers, etc. in your trunk? Not a sub box but a housing to hold the subs and whatever else you want to put in there. I heard using fiberglass or foam and plastic sheeting...I have no idea where to start or whats the best material to use!
thatdamngood777
Postby JAYDEE23 » Fri Jul 15, 2005 6:04 am
hey im in providence r.i.
JAYDEE23
Postby JAYDEE23 » Fri Aug 05, 2005 8:50 am
go to crutchfeil.com..they have a good tutorial..
JAYDEE23
Postby JAYDEE23 » Fri Aug 05, 2005 8:51 am
go to crutchfeild.com..they have a good tutorial..
JAYDEE23
Re: Creating housing for trunk subwoofers
Postby OKANG » Fri Aug 05, 2005 9:09 am
thatdamngood777 wrote:Does anyone know a good site to go to that has information on how to build a housing for subwoofers, amplifiers, etc. in your trunk? Not a sub box but a housing to hold the subs and whatever else you want to put in there. I heard using fiberglass or foam and plastic sheeting...I have no idea where to start or whats the best material to use!
Are you talking about an amp rack? Trim pieces?
JAYDEE23: Please edit instead of double and triple-posting.
Cogito Ergo Zoom
OKANG
Postby JAYDEE23 » Fri Aug 05, 2005 12:55 pm
check the dates ....OKANG..second one was an accident..first time for everything ya know.. :evil:
JAYDEE23
'Glassin
Postby tmanana » Mon Aug 08, 2005 12:28 pm
If you want to see what you are geting into with fiberglassing check out the following link:
http://web.njit.edu/~cas1383/proj/main/
That's the best write-up I've seen so far.
2002 National Sound Pressure League Record Holder - '01 SE
tmanana
Postby thatdamngood777 » Thu Aug 18, 2005 2:51 pm
Thanks! That page will help a lot.
thatdamngood777
