SolaraGuy.com • View topic - BOX DESIGNS FOR 2000 SOLARA V6 TRUNKS???
Postby JAYDEE23 » Sat Jul 23, 2005 7:59 am
i am in the proccess of designing a sub box for 2 10" oz audio elite subs. i was going with one box behind the back seat but then i saw some seperate box designs made to fit on the side recesses in the trunk..
with this setup you are left with most of your trunk space. anyone do this? pics or links to any solara box designs in the trunk would be great thanks
JAYDEE23
Postby JAYDEE23 » Mon Jul 25, 2005 8:47 am
SEE this is what it looks like..i really think it maximizes space
anyone else have any good box designs for our solaras? anyone into audio?!!!
JAYDEE23
Postby cam2Xrunner » Mon Jul 25, 2005 11:30 am
Are you willing to fiberglass? That's probably the best way to do the side enclosure thing.
For some ideas, search Sounddomain and check out other people's installs.
If you're willing to go all out, I'd put the subs in the rear deck and build a sealed enclosure for it.
cam2Xrunner
Postby JAYDEE23 » Mon Jul 25, 2005 2:37 pm
no to much going on to dedicate that much to the install..still have deadener ahead of me..box building..install.tuning..trd kit etc...
lot of work around my already hectic schedule
duh...forgot the link im my last post..this looks like a good setup to maximize trunk space...maybe customize the plain old boxes alittle with some trunk matching curves
http://www.sounddomain.com/ride/155968/2
it is the first setup with seperate boxes not the second
i only have 10's(matrix elites...deep mounting) so only need about .85 for sealed app.
and with the amps under a nice amp rack with a plexi top to show em off and a fan to cool the inside i can still use the top of the amp rack/box for trunk space if needed and keep my spare tire
only concern is how i will get to the tire..wanted to bolt the boxes to the chassis..so many ideas so little time and money!!!!!!
JAYDEE23
Postby Jackass-Jeff » Mon Jul 25, 2005 3:22 pm
remove the spare, drop a box in the spare well and put a false floor w/ fiberglass 'window' to see the subs. Then you can use the whole trunk (minus the extra height of the floor) w/o worries =]
Just add some fiberglass and sink the subs slightly.
1GR-FE ftw!
Jackass-Jeff
Postby Mandarinsolara » Mon Jul 25, 2005 3:24 pm
lol nothing in particular has to be so "SOLARA V6!!!!!!!!!!!!!!!" about your title
Mandarinsolara
Postby Adum-Bom » Tue Jul 26, 2005 1:01 pm
Im currently working on my fiberglass project for the solara. Heres some recent pics...
99' SLE V6
My Garage
I can so some pretty SWEETTTTT jumps :)
Adum-Bom
Postby OKANG » Tue Jul 26, 2005 1:47 pm
Adum-Bom: two 12's? What's the internal volume of that enclosure?
Cogito Ergo Zoom
OKANG
Postby Adum-Bom » Tue Jul 26, 2005 6:28 pm
Good guess :)
Yea, two 12" Elemental Designs ED12K (older "boob" style)
Estimating with just the rings and packing peanuts its 2.0cubes +-.10 i think. Ill get back in there with peanuts when this final layer drys by tommarrow.
Ive got (maybe) bondo tommarrow, dremmeling the excess around the rings, drilling a hole for speaker wires and carpet, then im done with this LONNNGGG project.
Even though its fun and very cool, im sticking to my usuall MDF next time, i just had to TRY fiberglassing...
Before my last two layers (two views)
99' SLE V6
My Garage
Adum-Bom
Postby OKANG » Tue Jul 26, 2005 6:48 pm
Looks good. I've got all the materials (including the sub) to make a similar box for a single 10. How long did that take? How much mat and resin did you use?
Cogito Ergo Zoom
OKANG
Postby Adum-Bom » Tue Jul 26, 2005 7:01 pm
Well ive used
9 (9sqft) of fiberglass matt $6 each
2 gallons of resin $64
99' SLE V6
My Garage
Adum-Bom
Postby JAYDEE23 » Wed Jul 27, 2005 8:55 am
i am trying to avoid fiberglassing but the removed spare tire would only require a sealing coat on the trunk floor huh? this is an idea..
is the top portion of the box mdf? if so did you drop the box into the fiberglassed floor and seal the floor to the opend bottom box? what volume did you endup w/ and how did you calculate it? did you just use the bottome as a "flat" panel for volume determination purposes?
have you ever been sorry you didnt carry a spare? that is one thing that worries me a bit..
as for the title :agrue:
JAYDEE23
Postby Adum-Bom » Wed Jul 27, 2005 1:41 pm
Im gonna jump in on this...
Fiberglass the entire spare tire section with about 2 layers of glass, then pop it out. Continue with glassing the inside of the mold till theres 5-7 layers of glass. The fiberglass is stronger in the curvyer parts. Then when your done with the 5-7 layers drop it back in there and mark along the top area (so trim about 2.5" off the top to allow for the MDF thickness and the woofers excursion) or about 1.5" if you do fiberglass.
If you do it with fiberglass you will need more materials (resin/glass) if with MDF you only need to do it along the edges for like 4 layers probally to seal it good.
To caculate the cuft you can either fill it with water, probally not a good idea just in the trunk unless you lay down a trashbag and fill it in there. Or what i did, packing peanuts. Then throw the peanuts into a box, measure the space the peanuts take up...
So if you fill a box thats dimentions are 12x12x12 then you have about 1.0cubes there. I would guestimate the spare tire area is around 1.5-2cubes just to give you a hint.
99' SLE V6
My Garage
Adum-Bom
Postby JAYDEE23 » Fri Aug 05, 2005 8:50 am
Adum where did you get that carpet to match the solara trunk?
JAYDEE23
Postby Nutty101 » Fri Aug 05, 2005 10:33 am
JAYDEE23 wrote:Adum where did you get that carpet to match the solara trunk?
Homedepot has it here. There are also a ton of places that do boats and other auto stuff who sell that same stuff. Call around you might be amazed. I pay 3.20 per square yard.
Nutty101
