SolaraGuy.com • View topic - Aftermarket HU? Stock JBL?
Postby Mossy » Tue Jul 26, 2005 5:26 am
I have a 00 Solara V6 SLE with the JBL 6 Disc In-Dash Changer.
I want to add my two 15 inch Kicker CompVrs to the trunk.
I want to have full control of the woofers and speakers.
I have an Aftermarket HU. That could control the AMP.
My question is? Can I buy a harness that will hook up my JBL system in my Solara to my aftermarket HU.
I really do not want to have to buy all new speakers and Amps. I would much rather just a harness to use the stock speakers.
Thank You Very Much.
[Silverstars|Nokya Yellow Fogs|Black Clear Corners|Pioneer DEH-P7700MP|Kicker 15" CompVR|Hifonics Amp|Knuconceptz]
Mossy
Postby cam2Xrunner » Tue Jul 26, 2005 2:26 pm
cam2Xrunner
Postby Adum-Bom » Wed Jul 27, 2005 2:11 pm
What if you have somthing like this
http://www.circuitcity.com/ssm/Tsunami- ... tDetail.do
99' SLE V6
My Garage
I can so some pretty SWEETTTTT jumps :)
Adum-Bom
Postby cam2Xrunner » Wed Jul 27, 2005 9:29 pm
^that's what he would need if he was keeping the stock stereo, but it looks like he is going to be using an Aftermarket CD player.
cam2Xrunner
Postby Adum-Bom » Wed Jul 27, 2005 9:36 pm
Well thats what im installing tommarrow, if it isnt that bad ill keep it till i find the time to change out to another HU.
99' SLE V6
My Garage
Adum-Bom
Postby OKANG » Thu Jul 28, 2005 4:06 pm
The problem I have with line-level converters is that you lose the ability to power the speaker. So, you use a line-level converter on one of your speakers (probably rear) to get signal for your sub. Then you have a dead speaker unless you add another amp for your mids. If you're going to do that, you might as well go completely aftermarket and have the ability to skip the external amp for the mids.
Cogito Ergo Zoom
OKANG
Postby Adum-Bom » Thu Jul 28, 2005 4:51 pm
Actually, i installed it and my rear speaks still work, i just pluged it in with the rear speak wires...
99' SLE V6
My Garage
Adum-Bom
Postby OKANG » Thu Jul 28, 2005 5:17 pm
How is that? Don't you remove the wires from the rear speakers and put them into the converter? If so, how do the speakers get signal? If not, how does it work?
Cogito Ergo Zoom
OKANG
Postby Adum-Bom » Thu Jul 28, 2005 6:50 pm
i just took out the push pins, stuck my wire in with it, pushed it back in and "wala!" there not as loud as they use to be, but still have sound...
99' SLE V6
My Garage
Adum-Bom
Postby Mossy » Sun Aug 07, 2005 9:06 pm
How did that go with the inline converter?
Mossy
Postby B_Master_Flash » Wed Aug 10, 2005 4:09 pm
Its called an integration harness or something like that. It feeds your preouts to the stock JBL amp.
B_Master_Flash
Postby JAYDEE23 » Wed Aug 10, 2005 6:31 pm
B_Master_Flash wrote:Its called an integration harness or something like that. It feeds your preouts to the stock JBL amp.
i believe he just spliced the line driver into the speakers..splitting the signal between the two..
JAYDEE23
