SolaraGuy.com • View topic - Ipod Mini and Ipod?
Ipod Mini and Ipod?
Ipod Mini and Ipod?
Postby Mossy » Mon Aug 08, 2005 2:36 pm
Do they use the same dock connector thing?
If I had an Ipod Mini could I use it with a CD-IB100 from Pioneer?
Thanks. :)
[Silverstars|Nokya Yellow Fogs|Black Clear Corners|Pioneer DEH-P7700MP|Kicker 15" CompVR|Hifonics Amp|Knuconceptz]
Mossy
Postby SpeedSTARs » Mon Aug 08, 2005 2:47 pm
:D I got that Pioneer IPOD interface. I believe the recharging dock ports are the same. Otherwords, the Gen1-current are the same. The Mini should follow suit. Just check out the bottom connection at a local Best Buy to see for yourself. Check the 20-40 gig IPOD to the IPOD MINI power plug. Hopefully this helps Bro. :wink: :D
SpeedSTARs
Postby Jon11582 » Mon Aug 08, 2005 4:32 pm
Port is the same for all Docking Ipods (Gen3+ I think) and Ipod Minis (all).
2000 Black Solara SE
Jon11582
Postby Mossy » Mon Aug 08, 2005 8:35 pm
Thanks guys. I just bought the 1 gig Ipod Shuffle. I bought a Sony Cassette Player Rig. I love playing the shuffle. But I want to be able to control it with my new HU Im going to install. Thanks alot guys. :) Cant control an Ishuffle with any unit. So I will just buy a bigger Ipod. :)
Also?
Where would a good location to put the actual unit the brain I suppose. under my seat? Under the dash? I need to connect a 12 volt fuse power source? Can I just jump off the power wire to the HU? or is that a bad idea? Should I just run a new fused line from the battery? Thanks? 8)
Mossy
Postby RichD978 » Tue Aug 09, 2005 3:33 am
if you want the ipod mini... i know who you can go to bro :wink:
RichD978
