SolaraGuy.com • View topic - Woofer Mount Question.
Postby Mossy » Sat Aug 27, 2005 8:17 pm
My question is. In the past I have always had just plain MDF boxes. Never had a precarpeted box. The carpet has not been trimmed around the subwoofer seal.
Should I put my subwoofer in the box. Take a razor and trim around the outside edge of the subwoofer? Then remove the sub and take that carpet off to make a flush seal.
Do I need to use any caulk or anything of that sort (I never have in the past)
[Silverstars|Nokya Yellow Fogs|Black Clear Corners|Pioneer DEH-P7700MP|Kicker 15" CompVR|Hifonics Amp|Knuconceptz]
Mossy
Postby firegate » Sat Aug 27, 2005 8:40 pm
Genereally, the pressure of the subwoofer against the MDF (or the carpet for that matter) forms a good enough seal providing it's screwed down properly. If you can't hear any air noise coming from around the sub when it's playing, you're probably okay. If you do, make a little gasket to go around the sub cutout out of weatherstripping and that'll take care of it.
firegate
Postby Mossy » Sat Aug 27, 2005 8:48 pm
I dont see the need for the caulking.
But I think the carpet will be a lot less air tight than just the mdf to subwoofer mount ya know?
Thanks.
Mossy
Postby firegate » Sun Aug 28, 2005 12:41 am
Mossy wrote:I dont see the need for the caulking.
Thanks.
Not caulking - just regular foam weatherstripping.. although you can use rope caulk too; it works rather well particularly when you're trying to flush mount the driver.
Either way, if there is an air leak around a subwoofer, it'll be audible - there should be a whistling noise coming from whereever the leak is. If you don't hear one, I wouldn't worry about it.
firegate
