SolaraGuy.com • View topic - sub box
sub box
sub box
Postby krook » Sun Dec 29, 2002 11:48 pm
i'm gonna rebuild the piece of sh!t excuse that houses my sub. what material should i use? particle board seems too cheapy. ideas?
krook
Postby Gunman » Sun Dec 29, 2002 11:54 pm
medium density fiberboard with cross brases or fiberglass an enclosure for looks to go along :D
Gunman
Postby Peter » Sun Dec 29, 2002 11:55 pm
Gunman wrote:medium density fiberboard with cross brases or fiberglass an enclosure for looks to go along :D
what are cross brases?
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby krook » Sun Dec 29, 2002 11:59 pm
fiberglass resin?
krook
Postby Gunman » Mon Dec 30, 2002 12:05 am
a cross brace will help stop a sub box from ''flexing'' keeping it solid and performing best, and resin yes, very trick looking :wink:
Gunman
Postby nkx1 » Mon Dec 30, 2002 9:30 pm
A while back, I made my own box out of 5/8" MDF. I made it exactly to the sub airspace requirements, and it was indestructible. I used wood glue and also high-quality screws about every 3 to 4 inches on every side. Then I sealed it with silicone caulking on the inside. Although it had no internal bracing (it was only for 1 12"), it was a badass box, very sturdy, and air-tight. Shouldn't have sold it.
2001 SLE, Diamond White Pearl
nkx1
Postby NaptownSolara » Tue Dec 31, 2002 8:24 am
Sounds like a good box, nx. Only thing I'd have changed is the MDF width to 3/4 to 1 inch for a little more strength (especially without bracing).
2001 Toyota Solara SLE V6 - Silver
Alpine/Kicker audio system
NaptownSolara
Postby nkx1 » Tue Dec 31, 2002 11:44 am
Only reason I didn't use thicker MDF is because of weight. I thought 5/8" was a good comprimise between strength and weight (not as thick as 3/4, but thicker than 1/2). My '88 Integra (my car at the time) only had 117hp, so I didn't want to bog it down with a really heavy box.
nkx1
