SolaraGuy.com • View topic - H/U to Amp RCA Cables
Postby TRAFFICBLOWS » Sun Oct 16, 2005 8:28 pm
Does it really matter what type of RCA cables are used to connect a head unit to an amp?
Also, what's the approximate length needed, if the amp is in the trunk?
What do you think about one of these 6-ch cables so front/rear/bass are in one easy bundle:
Monster 6-channel RCA cables
99 Titanium SLE... 10-yr birthday Aug '08! She's slowly falling apart... :cry:
TRAFFICBLOWS
Postby Jackass-Jeff » Sun Oct 16, 2005 9:11 pm
the cable does matter.... those monster ones will do just fine
You will need about 17 feet for a pretty safe length. I ran 16 feet which was just enough... so 17 should give you some room to play with.
A decent RCA set will run around $90 anyhow... so may as well spend the extra few bucks for the monsters =D
Jackass-Jeff
Postby ZXLNT » Sun Oct 16, 2005 11:36 pm
I dont think its really neccessary o spend 90 dollars on RCA cables. Any decent shielded set will work fine. Fosgate, stinger, etc.
ZXLNT
Postby Jackass-Jeff » Mon Oct 17, 2005 12:09 am
well, i'm rnning rockford fosgate RCAs and it's fine... the 17 (or was it 16?) foot sets cost about $20 each +/-
Jackass-Jeff
