SolaraGuy.com • View topic - can we fit 7" mids in our front doors? 2000 v6 solara?
Postby JAYDEE23 » Fri Oct 28, 2005 11:01 am
anyone have any experience with trying to fit a 7" mid in our doors? any input would help..thanks
JAYDEE23
Re: can we fit 7" mids in our front doors? 2000 v6 sola
Postby Vampire » Fri Oct 28, 2005 3:31 pm
Most likey yes, I fit an Excel W18 in there with a 1/2 inch MDF trim ring but as always you need to check the depth. The reason I said likely is because some manufacturers make strange speaker baskets.
JAYDEE23 wrote:anyone have any experience with trying to fit a 7" mid in our doors? any input would help..thanks
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby JAYDEE23 » Fri Oct 28, 2005 5:45 pm
that is a mid i considered..i just want to know what mids fit. how do you like it? tweets? active? power?
any other experiences fiting some diy mids or 7"..also if anyone know the max mounting depth that would be great too!!
JAYDEE23
Postby Vampire » Fri Oct 28, 2005 8:52 pm
I like it a lot. Good low end and detail. I have the LCY 110 ribbons and use an Eclipse 8455 for an active a 2-way front stage. The mids are powered by a Zed Deuce at 100 watts per rated for 8 ohms. The ribbons at 37.5 per at 8 ohms by a PG Ti 500.4.
You really need to go in there once and take measurements. The physical specs are avilable for most speakers so that should do you.
JAYDEE23 wrote:that is a mid i considered..i just want to know what mids fit. how do you like it? tweets? active? power?
Paul
Vampire
Postby JAYDEE23 » Sun Oct 30, 2005 8:29 am
Vampire wrote:You really need to go in there once and take measurements. The physical specs are avilable for most speakers so that should do you.
yeah i will have to if no one else has..just wanted to save myself the trouble if someone has gone through it already..if i do end up doing it ill list the results..
mids are 8 ohm huh? i hear alot about the 8 ohm deal not mattering much but this definitely does not apply to subs. I would guess mids are a bit different because of the relatively small amount of power they require.
i am so stuck on what the hell to get for the front. i have had nothing but factory (aftremarket) sets and want a diy'er but am worried about balancing the hard midbass i like and sq. a 3 way seems like the answer but i dont think i want to go there..not yet anyway..no kicks etc..
JAYDEE23
Postby Vampire » Sun Oct 30, 2005 5:28 pm
Well if it helps I believe the W18's measured to about 3 1/4 inches depth and I experimented mounting it directly to the door temporarily and it cleared. Now as for the hole diameter, a shallow trim ring should give you no problems with a 7 incher. Bigger than that and you're on your own :wink:
I think we all have concerns about doing things to the interior but if you want the best sound (imaging etc.) from your investment, you have to make some sacrifices. In my opinion the rewards are worth it.
Paul
Vampire
