SolaraGuy.com • View topic - is there anything for non-ipod radio broadcast gadgets?
Postby Mole » Wed Nov 09, 2005 12:32 pm
ipod has their little gadget where you can play the ipod through the radio using a frequency that no station uses.
is there anything for non-ipod accessires? i have a creaative mp3 player..
TIA
Postby solaraslev67 » Wed Nov 09, 2005 12:40 pm
i also have a creative mp3 player, the creative zen xtra and would love it if i could hook it up, anyone with info would be greatly appreciated.
solaraslev67
Postby cklinh » Wed Nov 09, 2005 12:45 pm
Just search for FM Transmitter. You won't get the design of the ones made specifically for the iPod, but it'll work.
The generic ones (ie, not made for any specific player, not that they're generic companies) just have a ministereo cable that you plug into the sound out of your player.
do a search for "fm transmitter -ipod" on ebay and you'll see some...
Here's something to look out for...
Some transmitters only transmit to three or four preset frequencies... if you're somewhere where all those frequencies are used, tough luck... so I'd look for one that can be set to any frequency.
cklinh
Postby Yanks0114 » Thu Nov 10, 2005 1:22 pm
it shouldn't be a problem to find a generic one as cklinh said. The real term is a FM Modulator.
However, you do lose quality when you go with a FM Modulator
Postby Jack Soulfire » Tue Nov 15, 2005 5:21 pm
Yanks0114 wrote:However, you do lose quality when you go with a FM Modulator
SIGNIFICANT quality.
i.e. sounds like crap. :-?
2006 V6 Solara SE Sport
Jack Soulfire
Postby NeFaRiOuS_SLE » Tue Nov 15, 2005 10:33 pm
Yeah, if you still have your stock radio, you're better off getting a cassette adapter.
STOCK HU:
Simple as putting in tape, connecting other end to MP3 player, done.
AFTERMARKET HU (This is where it gets tricky):
If it has an RCA jack (the red and white ones you usually see on DVD/VCR/TV sets; yellow is for video and not used for sound, of course), go to RadioShack and get an RCA male to 3.5mm adapter. Here's 2 options:
RCA Male > 3.5mm female: Also buy a 3.5mm male to male connector (eww :lol:), and route the RCA end to your HU, then drill an inconspicuous hole somewhere and make it a jack (e.g. next to 2nd jack below ashtray), then plug the connector into the jack and then to the MP3 player.
Advantage:
Stealth when not in use, the connector wires are a lot thinner
Disadvantage:
You'd have to have the 3.5mm connector somewhere handy.
RCA Male > 3.5mm male: connect the RCA end to your HU and the 3.5mm end directly to your MP3 player and route it through the back of the ash tray (or even inside the glove compartment).
Advantage: Won't need a connector
Disadvantage: the presence of thicker wires, wires may disappear into glove compartment if not secured to something or unable to close ash tray after installing through ash tray, and *EDIT* you won't be able to control your MP3 player if it's in the glovebox.
To play, tune your radio to AUX mode; some radios would need you enable AUX mode beforehand (true with Pioneer) and jam away. If I ever get an MP3 player, I'd do the same thing, so thank you for getting me thinking since I'm not a big fan of Apple, Inc.
Postby juicedsolara » Tue Nov 22, 2005 12:05 pm
you guys apparently have never used a legitamite fm modulator, not some Ibeam peice of crap. Go to BB or CC and get an fm modulator, they run about 40 to 50 bones. you have to tie into power ground and your antenna. You have to wire up a switch on the fm modulator, you have to turn it off when your not using it, or else you won't be able to listen to normal radio. You will also need to by a headphone to rca wire, this will plug into the fm modulator. you will need to unplug your antenna from the radio, plug it into the fm modulator and then use the fm modulator antenna wire and plug it into the radio.
this is your option beside going to an aftermarket radio.
juicedsolara
