SolaraGuy.com • View topic - install pics
install pics
install pics
Postby JAYDEE23 » Fri Nov 11, 2005 9:00 pm
got some work done finally ill post up some details later..
got tint since this
aura mr62 sealed permanantly to stock baffles
trunk done
everything using stock connections ..for now..
doors done mids mounted
and trunk w/ amp bolted to mfd bolted to box bolted to floor
JAYDEE23
Postby Dimik » Fri Nov 11, 2005 9:27 pm
very nice and clean!!! thumbs up!
Dimik
Postby Hsakuragi » Fri Nov 11, 2005 9:36 pm
cool...good job!
Hsakuragi
Postby BradOwens » Fri Nov 11, 2005 10:01 pm
nice. hows it sound? no rattling im guessing lol
BradOwens
Postby SleeperSolara » Fri Nov 11, 2005 10:08 pm
Looks good man.
Postby JAYDEE23 » Sat Nov 12, 2005 8:52 am
yeah no rattles at all...remember the thread about making your doors shut like more expensive cars...this is one way..deaden the shiat out of them..
got two layers of raammat on the outer panel. mat where i could fit it on the inside of the inner panel, and 2-3 layers on the outer inside panel. had to remove some in places to get the door panel back on..
trunk has 1 layer on floor, and two layers on walls and rear deck..also have a layer and foam between the trunk and the cabin..oh and the plastic panels that line the trunk are all done too w/ a single layer
the area between the trunk and cabin could be the source of rattles if left unchecked..its plastic directly against metal..
believe it or not the stock jbl systems in these cars w/ a little extra power produce very nice midbass. the aura replacements i have in need much more power to equal the output of the stock stuff @ about 20 watts a speaker or so..sq is much better now though
next step is new components (think i am going back to cdt hd62's)
and a 4 ch. amp to run fully active..
JAYDEE23
Postby NeFaRiOuS_SLE » Sat Nov 12, 2005 7:25 pm
That's friggin' tight. Just remember to erase your plates.
Postby Nyyankees3511 » Sat Nov 12, 2005 8:58 pm
i should check your car out sometime if of course you dont mind i live in RI too.
Nyyankees3511
Postby cam2Xrunner » Mon Nov 14, 2005 10:24 am
Very nice install man. How do you like the Oz Matrix Elite?
Oh and you might want to swoop up on these 180CS's
http://forum.elitecaraudio.com/showthre ... did=121599
cam2Xrunner
Postby bassthrive » Mon Nov 14, 2005 4:19 pm
nice job!
where did you get that sub grille? mine needs some protection.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby JAYDEE23 » Thu Nov 17, 2005 5:02 pm
got it from parts express (the grille)
i made an offer on those elites..wasnt high enough and for 260 i think i will try the diy route although i hear they are nice...
i just won an opti 1400d from ebay for 100 bux new.
and i am buying a 160 amp alt next week hopefully..(i hope solara!!) so components are going to have to wait a couple more weeks..
pics look kina crappy..goona redo it once i get the opti in..prolly going to get a bigger sub too as long as the alt goes through..
JAYDEE23
