SolaraGuy.com • View topic - Amp wiring kit
Amp wiring kit
Amp wiring kit
Postby skadoo323 » Tue Jan 24, 2006 2:06 pm
Quick questions for those who have installed amp wiring kits in their Solaras. Was there some grommet or hole that you could use to run the wires through the firewall or did you guys drill holes in the firewall? Thanks for the input. I have been outta town for work so I haven't had a chance to look at my Solara. I'm trying to prepare for a weekend project.
skadoo323
Postby Mr. Slippery » Tue Jan 24, 2006 2:16 pm
I know in my Gen 2 it was a tight squeeze in there. I drilled a new hole, there was no way I was jamming any 4 guage wire through any existing openings. Just be sure not to drill through the vacuum for the brakes, I learned that the hard way a few years ago. :(
-MATT-
Mr. Slippery
Postby WunLoudSolara » Tue Jan 24, 2006 3:40 pm
I have an auto and drilled through where the clutch resevoir would be, fit 1/0 gauge in there.
2000 Toyota Solara SE V6
Injen CAI
Gredy Evo
2 Power HX2 15
RF Power 1500bd & 450s
Sony CDX-M850MP
200Amp EA Alternator
Optima Blue Top Battery
MB Quart Premium 6 1/2 Components
WunLoudSolara
Postby Adum-Bom » Mon Feb 06, 2006 8:58 am
THis hose goes under the glove compartment, no need to drill thru any metal, easy to do, and easy to cover up if you dont have a system anymore...
99' SLE V6
My Garage
I can so some pretty SWEETTTTT jumps :)
Adum-Bom
Postby Solarafreek » Mon Feb 06, 2006 9:13 am
Yup..... thats the easiest place I found
Solarafreek
Postby skadoo323 » Wed Feb 15, 2006 5:12 pm
Thanks for the pic and advice guys. I ended following your advice when I installed my wiring.
skadoo323
Postby bassthrive » Wed Feb 15, 2006 9:12 pm
Enlarged existing hole on driver's side firewall for 4ga. (same hole for alarm system horn wire) Used a grommet.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
