SolaraGuy.com • View topic - Rattling noise from trunk area when playing music.
Postby DrakkkarDarkbladE » Tue Jan 24, 2006 5:20 pm
This really annoing rattling or vibration is comming from the passenger side of the car from the back speaker/trunk area, when the audio is on and the bass kicks in, it is very annoing since you can no longer listen to music without this rattle and it is really pissing me off. Anyone here know what that can be and if there is a easy way to fix it.
thanks in advance.
Post in the correct forum. This is your last warning,
-Mole.
2002 SLE V6
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
DrakkkarDarkbladE
Postby redkysolarase » Tue Jan 24, 2006 6:11 pm
Dynamat might be able to fix that.. or do you already have some in there?
redkysolarase
Postby krook » Tue Jan 24, 2006 6:20 pm
if it's in the trunk on the passenger side, it might be that your jack is loose. go investigate sherlock and report back in five.
krook
Postby BradOwens » Tue Jan 24, 2006 6:49 pm
do u even have subs? mine dosent rattle so bad and i have 2 10"s. the only thing tht rattles bad is the spoiler and u can only hear tht from outside. but yea some dynamat will fix ur problem.
BradOwens
Postby SolaraGuy22 » Tue Jan 24, 2006 8:15 pm
That happens to me but when I look back in the seat it turns out to be the passenger seatbelt that's pressed against the plastic.
Do you have subs?
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby 1st Gen Sol » Tue Jan 24, 2006 10:09 pm
Dynamat will take care of most of your rattling. As others have said, check your spare & jack along with your spoiler.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby DrakkkarDarkbladE » Wed Jan 25, 2006 7:14 am
I do not have a sub, I just checked the jack and that was not it.
What is a dynamat?
2002 SLE V6
DrakkkarDarkbladE
Postby SleeperSolara » Wed Jan 25, 2006 8:30 am
Yeah mine does that too, and all i have is Alpine Type S speaker in the back.
Dynamat is a dampenin' sheet that makes metal no vibrate as much when you have aftermarket speakers.
Only downside it get heavy when you put it on, ie more weight, and cost.
Postby krook » Wed Jan 25, 2006 8:54 pm
DrakkkarDarkbladE wrote:What is a dynamat?
this is dynamat:
the trick is to put the dynamat around the speaker and not over it.
krook
Postby Yanks0114 » Wed Jan 25, 2006 9:05 pm
your rear speakers are probally blown
Postby DrakkkarDarkbladE » Fri Jan 27, 2006 9:51 am
I don't know how but the problem just fixed its self.
2002 SLE V6
DrakkkarDarkbladE
Postby Smoothro » Fri Jan 27, 2006 10:39 am
As SolaraGuy22 said, it was more than likely simply the rear passenger belt against the plastic, especially if it corrected itself. This is really annoying, but its probably the only cause of rattling with a factory system.
Smoothro
Postby BigPhizzle » Sat Jan 28, 2006 2:51 am
I had a 15" Solo L7 hooked to a 1500w 1-ohm stble amp.. That sh!t bangged with the hardness.. but yeah I got some mad rattle. I found that it was many things... It started with the seatbelt against the plastic part behind the seat, easy to fix. I also had my trunk dynomatted with about 15 pounds of that stuff from my previous subs (2x10" solo baric) which also banged hardcore.. Anyhow after awhile, I figured the noise was coming from inside the cover above the rear seat, but right below the rear window.. The cover with the 2 speaker grilles on em.. You open that sucker up and theres a few hex head screws in there.. tighten them babies up and that should get rid of some of ur rattle, like it did mine.
- Big Phizzle -
BigPhizzle
Postby NeFaRiOuS_SLE » Wed Feb 01, 2006 10:46 am
I'm getting the same issue, except it's probably because I blew my speakers (because now only the highs come out of that speaker :lol:).
Solution?
Order Summary
Order Number: -NoT Yo BiZnAtCh-
Bill To: Edward [Can't see, neener neener neener]
address
address
phone
Ship To:
Same as above
Item Description Ship Qty B/O Qty Price Amount
130TSA6991 Pioneer TS-A6991R 6"x9" 5-way Speakers
1 0 149.99 149.99
15410415 Dynamat 10415 Xtreme Speaker Kit, 10-in. x 10-in. 2 Sheets
What's Included 1 0 19.99 19.99
(yes, I will eventually Dynamat every square inch of the car in the future, but now's not the time money-wise)
