fiberglass
anyone know how to work with fiberglass? i want to try and experiment with it to fabricate things for the interior and trunk.
- krook
- SolaraGuy Supporter
lilmike2069 wrote:Fiberglass is pretty easy to work with... theres essentially two types of fiberglass. There is the cheaper kind... which you can't really use with styrofoam because the chemical reaction will melt it. Then there is a more expensive kind that wont melt styrofoam. The benefit of using styrofoam is that you can pretty much make any shape or design with it. Just remember to use wood supports if you make a fiberglass sub enclosure
lilmike2069 wrote:krook: Just another tip,if you are planning to work with styrofoam, you may want to look into getting a "Hot Knife" or there is like a cheesegrater sort of thing that works extremely well in shaping your project.
