SolaraGuy.com • View topic - fiberglass box
fiberglass box
fiberglass box
Postby blakey2007 » Thu Apr 27, 2006 10:03 am
hey im getting ready to buy some new subs sometime soon and was really interested in a fiberglass enclosure i know some people have them and i was just wondering how much you guys paid?
130 top speed jenson 7" flip up dvd, 2 10" kicker comps 150.2 kicker amp shaven emblems coming soon tb spacer and injen sri & painting grill black
blakey2007
Postby SolaraGuy22 » Thu Apr 27, 2006 3:37 pm
It can get pretty costly depending on what you want to do with it, what kind of subs they are, and what you want to paint the enclosure ya know.
I'd be interested to know as well.
What kind of subs are you getting BTW?
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby blakey2007 » Thu Apr 27, 2006 7:51 pm
i dont know i really would like a w6 or like a eclipse titanium
blakey2007
Postby Monkeyman » Sat Apr 29, 2006 8:09 pm
You can do it yourself, it is VERY easy! If you want some instructions let me know (check out my fiberglass work on my kick panels: http://www.solaraguy.org/viewtopic.php? ... highlight= )
I am currently making a glass sub enlousure for my new Morel-USA (now called Renaissance audio) Cannon sub. I will be taking pics of my work, and can send them to you.
www.RENaudio.com
http://www.renaudio.com/carstereo/canon.htm
Hope this helps,
David
Monkeyman
Postby blakey2007 » Mon May 01, 2006 7:39 pm
thanks david thosepics look really good how long did it take u to do? and how much money did u spent on it?
-blake
blakey2007
Postby Monkeyman » Tue May 02, 2006 9:28 am
It took me about 4 hours (but I used a heat gun to speed up the cure time of the fiberglass). Here is a price break down:
Glass cloth: $5.00
Glass mat: $5.00
Glass resin: $11.00
Bondo: $8.00
Vinyl: $16.00 per yard (used less then 1 yard for kick panels).
Spray adhesive: $9.00 per can (used less than 1 can)
Total: $54.00
Matching the vinyl to the cars interior took hours (3 hours). You need to pull one of your kick panels off and bring it to your nearest (largest) fabric shop. Compare it to each and every roll they have (which is about the same color) even if you are sure you have matched it very closely. I should be starting the subwoofer on friday night, and should have it done by sunday afternoon (I am re-doing the entire trunk to match the interior of the car, so it may take me two weekends, but NO other Solara's trunk will look as good!).
Monkeyman
Postby Adum-Bom » Mon May 15, 2006 7:46 am
My write up is in my profile (box for sale)
99' SLE V6
My Garage
I can so some pretty SWEETTTTT jumps :)
Adum-Bom
Postby Monkeyman » Mon May 15, 2006 8:03 pm
Adum-Bom, I like the thought you put into your design, with the angles on the subs and what what, but you are missing two important things:
1) You should have seperate air space for each sub. Translation: you should split the box down the center internally so both subs have seperate enclousures.
2) One of your subs has a forward leaning position, it should be facing twards the rear of the car for the best sound.
Other than that you did a very nice job.
David
Monkeyman
