SolaraGuy.com • View topic - Aftermarket deck with stock amp
Postby rec » Wed May 24, 2006 9:39 am
I just bought a Jensen Mobile Multimedia Receiver with 6.5" LCD (VM9020TS) for my 2002 toyota solara. I Have the premium sound system by jbL and the stock deck. I want to use the dvd with the stock amp, i dont want to bypass the amp because i want it so it could give the dvd a lil more juice. Is this possible ?
rec
Postby Ispeedbyu » Wed May 24, 2006 8:32 pm
No.That is not possible.Much better off just diconnecting it and hooking up directly to your factory speakers.When you remove your factory head unit there are two plugs off to the right side that are your standardtoyota plugs.they give you power and speaker connections....Cee
Designed With A Purpose,Built For Sound
Ispeedbyu
Postby st.augsolara02 » Wed May 24, 2006 8:41 pm
which jensen did you get? i just got the 2-DIN dvd put in my 02 solara and am kinda disappointed..i cant seem to get the equilizer settings right to give it the right amount of bass to sound good without soundin like its too much for the factory jbl's..is it just me or was the bass output from the stock h/u better..at lower volumes atleast
So long Solara...Hello IS300!!!
New Project: '01 Autumn Sky Pearl IS300
* tien coliovers, 5% tint, SRT intake, HKS Carbon-ti exaust, 7" touch screen DVD, 2 12" Kicker Comp VR's
st.augsolara02
Postby rec » Thu May 25, 2006 9:07 am
i havent installed it because i did get the 2 din jensen. My couzin hooked up my aftermarket deck to a stock amp ounce using bare wires so thats why i was wondering. Hopefully he can do this again :) So what your saying is if i pay circuit city to install it they can just plug it in to the other plugs it has ? No re wiring the car ?
rec
Postby RichD978 » Thu May 25, 2006 9:13 am
your jensen will crap out in 3 months or less.
RichD978
Postby rec » Thu May 25, 2006 10:31 am
RichD978 wrote:your jensen will crap out in 3 months or less.
In what way will it crap out? :drinking:
rec
Postby rec » Thu May 25, 2006 11:54 am
hey st.augsolara02 i got the exact jensen you did. From circuit city how much did you pay for installation ? And did you have the premium jbl stock amp hooked up before the dvd ?
Mine is black.......
rec
Postby st.augsolara02 » Thu May 25, 2006 3:38 pm
rec wrote:hey st.augsolara02 i got the exact jensen you did. From circuit city how much did you pay for installation ? And did you have the premium jbl stock amp hooked up before the dvd ?
installation was 100 bux..yea i had the jbl system but didnt bother to ask what they did with amp didnt really want it anyway since it cant be used with the aftermarket unit..just a heads u tho its good to let them install it since theres a lot of wiring to do plus they had to run the tv antenna from the windshield to the h/u but when they put it in they have to hook it up the emergency brake so if u want to watch dvd or tv while ur driving youll need to disconnect the wire and ground it to the chasis thatll solve the problem and its pretty easy to do..also with the bracket they use it makes the screen stick out from the dash about half an inch or so. i took it out and adjusted the screws to make it sit deeper in the dash and it looks 20 times better..if u have any questions about how to do it just pm me and ill send u some pics
st.augsolara02
Postby rec » Sat May 27, 2006 11:56 pm
:bcrowd: i just had it installed by my couzin took 20 minutes and for free circuit city charged me $20 for the dam wiring harness and walmart had them for $5. Those fucken asswholes. I can watch dvds while driving :) i hooked the antennas to my back window and ran them through the sides of the car, you cant even see them :)
rec
