SolaraGuy.com • View topic - Orion amp Question
Orion amp Question
Orion amp Question
Postby Solarafreek » Fri Jul 14, 2006 6:32 am
I have an older Orion 900 xtreme and was wondering if it had any internal fuses. Thanks in advance. :fadein:
I really dont want to open it up unless I have to.
Solarafreek
Postby theprodigy79 » Fri Jul 14, 2006 11:49 am
I know it has two 30 Amp fuses... but I can't remember where they're located (I believe they're external)... If you see two fuses on the outside, then your answer is no.. If you don't, then they are on the inside.
theprodigy79
Postby Solarafreek » Fri Jul 14, 2006 11:56 am
Thanks Prodigy, I emailed Orion. No inside fuses. I cant get the amp to power up. They emailed me a manual. Im going to try again when I get home. :-?
Solarafreek
