SolaraGuy.com • View topic - best place to ground for parking bypass on indash dvd
Postby kilade » Mon Jul 24, 2006 1:48 pm
I just bought a jensen in dash dvd lcd. The install went great but im having a hard time bypassing the parking brake lock in order to watch dvds while in motion. I got a little one who needs to be entertain while in traffic. I tried grounding the wire to a screw behind the glove compartment but this didn't work. Where is the best ground??? Any special procedures such as disconnect battery, then ground, then connect???
Thanks for the help
kilade
Postby gasolara2002 » Mon Jul 24, 2006 2:41 pm
well did u cut your wires or did u buy the harness adaptor?
gasolara2002
Postby kilade » Tue Jul 25, 2006 3:19 am
i got an adaptor to connect the deck to the OEM harness but the parking ebrake wire comes straight out of the deck. It is supposed to be connected to the ebrake so you can;t watch movies unless the brake is on. I heard if you ground this wire it will bypass this lock. I tried grounding the wire but it didnt work. Looking for a better place to ground
kilade
Postby NeFaRiOuS_SLE » Tue Jul 25, 2006 11:24 pm
I know this seems like something that's been heard a million times, but are you sure it's a pure ground (as in, it's connected to a point on the chassis and all paint under the contact has been removed)?
Postby st.augsolara02 » Fri Jul 28, 2006 5:31 pm
i just got my jensen w/ ipod interface a couple weeks ago and have been wanting to do the same thing..what color is our ebrake wire and where the hell does it run too? ive looked at the wires and cant seem to find i must just be overlookin it..oh and does yours have a "sequence" on it? the guys that installed said you have pull and release the brake a bunch of times before it will work apparently its something on the new model cuz it didnt do it on my 9020 but it did when i got the 9021
So long Solara...Hello IS300!!!
New Project: '01 Autumn Sky Pearl IS300
* tien coliovers, 5% tint, SRT intake, HKS Carbon-ti exaust, 7" touch screen DVD, 2 12" Kicker Comp VR's
st.augsolara02
Postby gasolara2002 » Fri Jul 28, 2006 5:36 pm
wire it in to the ground wire with the harness adaptor. It works. That is what i did.
gasolara2002
Postby st.augsolara02 » Fri Jul 28, 2006 5:38 pm
so you wired the ebrake wire directly to the stereo harness?
st.augsolara02
Postby gasolara2002 » Sun Jul 30, 2006 8:12 pm
st.augsolara02 wrote:so you wired the ebrake wire directly to the stereo harness?
yea i bought the harness adaptor and wired it to the ground with the radios ground and it is working just fine.
gasolara2002
Postby Ramrod » Fri Aug 25, 2006 2:35 pm
Ok, so I did that (wire parking bypass to harness ground) and it was working fine, But after I turned the car off and turned it back on, it wouldnt let me view dvds. aka I got the blue screen of death. Any ideas on why this would be happening?? Please help..
Ramrod
Postby Ramrod » Sun Aug 27, 2006 5:55 pm
Just wanted to say I figured it out. On some newer models, so that you cant bypass the parking brake just by grounding it, they make you pump the parking brake a few times. To avoid this I installed a toggle switch with 3 prongs. One is the ground, the main one is the parking brake wire, and the third is the power which I got from the ACC wire. Hopefully this will help if anhyone else runs into this problem.
Ramrod
Postby RichD978 » Tue Aug 29, 2006 7:02 pm
just curious but why would you buy a jensen? it'll crap out on you in 2 or 3 months. I bet you paid $500-$600 for it. I'd rather get the high end eclipse cd player that's $700 that only plays music not movies. I like reliability and quality over affordability
RichD978
Postby st.augsolara02 » Mon Sep 04, 2006 8:51 pm
hey ramrod did that switch idea work for you? ithink ive got the same model as you (the 9021??) and u have to pump the brake to initiate the "sequence" or some BS..if it did work do you think u could post some pics of how u wired everything together or just some detailed instructions i'd really appreciate it
st.augsolara02
Postby Ramrod » Tue Sep 05, 2006 8:36 am
To answer the first question, I got the "crappy" jensen because its still 100 times better than the crappy stock radio i had which didnt play tapes or cd's anymore, just radio, and my ipod got old quick... Also, I got it through crutchfield, so if it happens to crap out in 5 years, they will still replace it...
Next, I have the Jensen 9411 model, but yeah, i think with all jensens you need to do the parking brake sequence. I will post pictures soon, but this is what i did;
1) bought a 3 dollar toggle switch at radio shack. I believe you can get either a 2 prong or 3 prong switch, mine is the 3 prong.
2) wire the parking brake wire to the main prong, ground the other one, and the third is the power, which I got by wiring the acc wire to(this is the red wire in the harness cord, i think it says acc in tiny print on the wire).
The switch I got also had the prongs labeled to help out.
3) I drilled a hole in the back of the pocket under the player and put the switch back there. This way you can activate the parking brake sequence if you want to watch dvd's while driving, but also, if po po wants to pull you over to be a pain in the ass, you can just flip the switch and its hidden so they cant search for the switch if there are cd's in front of it.
I'll post pictures soon of the final product..
Ramrod
Postby Ramrod » Tue Sep 05, 2006 8:38 am
also, hehe, i didnt write donkey, lol.
Ramrod
Postby st.augsolara02 » Fri Sep 08, 2006 3:23 pm
well i picked up the 3-prong toggle switch today and im gonna try to wire it up tonite but had a few questions first..the prongs on the switch are labeled 1, 2, 3 and on the back of the package it says the middle prong is the "main" and the two on the outside are "Load 1" and "Load 2"..so do i need to wire the e-brake wire to the "main" prong? and does it matter which "Load" prong i wre the ground and power to? by the way its a 3-way switch that you flip down for "on", middle for "off", and up for "on" again..is this the same kind u got?
st.augsolara02
