SolaraGuy.com • View topic - How to hook up subs to OEM HU???
Postby 01SolaraV6 » Thu Aug 10, 2006 7:38 am
how do i?
2001 Solara SE V6 (5speed) Silverstream Opal
Loaded
01SolaraV6
Postby RichD978 » Thu Aug 10, 2006 7:49 am
i think the correct question is
WHY WOULD YOU?
RichD978
Postby Smoothro » Thu Aug 10, 2006 8:15 am
I forgot exactly what the thing is called, but its somthing llike a line-converter. It is a little box that allows you to splice into the signal received by the rear speakers and send it to your amp. It does not give as good of sound quality as compared to a deck with sub pre-outs, but it will do if you do not want to switch out the OEM head unit.
Smoothro
Postby Mr. Slippery » Thu Aug 10, 2006 9:18 am
Yea it's called a line out converter. I use one and it's a total PITA. The sound quality is definately not as good as a new head with pre outs, and it takes a lot more tweaking to get it to sound good, but it does work.
http://davidnavone.com/
-MATT-
Mr. Slippery
Postby swindler » Thu Aug 10, 2006 9:29 am
A new head unit is definitely preferred, but as an additional option - many amplifiers, (particularly subwoofer amplifiers), offer a speaker-level input in addition to the pre-amp level inputs. If the amplifier you choose has that available, you don't need a line out converter, as the amplifier is already doing the signal level conversion for you.
2006 SLE V6 Convertible
swindler
Postby Turbosolara » Thu Aug 10, 2006 10:56 am
just need to add a voltage convertor that converts your speaker wire to RCA signal. i had that set up before, but it is not as good as an aftermraket headunit
Postby woa_its_j3ff » Thu Aug 10, 2006 11:52 am
RichD978 wrote:i think the correct question is
WHY WOULD YOU?
lol relax man, he's new..
cant believe u still have my quote in your signature.. by the way, i have perfected my sushi technique.. i really know how to "roll" :D
Postby WTF?? » Thu Aug 10, 2006 1:21 pm
WHY WOULD YOU?
Some ppl just rather not have an aftermarket HU so to keep theives away from smashing out ur windows
tell me what thief would want to bother with a stock HU?
Although you lose the quality of sound, but keeps sticky fingers away
vice versa, you have a nice HU, but run the risk of it gettin jacked
Not everyone has the same weight factor in this...
Retired... its been fun Image
WTF??
Postby sbsolara84 » Mon Aug 21, 2006 8:08 pm
Supplies:
Line out conveter (40-50 bucks at Circuit City)
RCA audio wires
Some T wire adapters.
-Leeche the rear R and L line from ur stock deck to the converter with the T adapters.
-Attach the RCA wires to the Conveter and attach the other end to the Line in on ur Amp.
The sound quality isn't as great as a deck with a subwoofer output, but you will get bass.
i had that set up before i got a new deck. I recomend a new deck
what kind of amp and sub are you getting and what wattage output?
...Ben
sbsolara84
Postby made in china » Mon Aug 21, 2006 10:02 pm
I tapped in to the signal coming out of the HU before the JBL amp. No need for a converter, and I just run a regular pair of RCAs to the sub amp...if I ever upgrade to a better HU, I won't need to run RCA cable to the sub...just pop in a new HU...and bypass the JBL amp.
I would NOT use a line out converter, the stock amp adds heavy loudness gain, your system will be too boomy at lower volume levels. If you take the line signal from before the JBL amp (if you have a JBL setup) you'll get very clean, line level signal without any loudness compensation. The loudness is handled by the amp, the stock JBL HU actually has a fairly clean signal....
Gettin' pirate eyed.......
2002 BSP SE V6 5 Speed
TRD RSB
5000K HID Headlights
3000K HID Foglights
Gen 1.0 Tails
Optitron Lexus Cluster
made in china
Postby DatSRBoi » Mon Aug 21, 2006 10:40 pm
sbsolara84 wrote:Supplies:
RCA audio wires
...Ben
OH WTF..... Line out in texas at circuit city are only 15 bucks and they are the good ones too.
Postby sbsolara84 » Wed Aug 23, 2006 1:35 am
sbsolara84 wrote:
Supplies:
RCA audio wires
...Ben
i could be wrong.....i bought it like 2 years ago. it was only installed for a month.
But i'm in Santa Barbara, CA. everything is over priced here
...Ben
sbsolara84
Postby sbsolara84 » Wed Aug 23, 2006 1:39 am
[/quote]I tapped in to the signal coming out of the HU before the JBL amp. No need for a converter, and I just run a regular pair of RCAs to the sub amp
Uhmmm.... sure if you wanna do that.
but i just found it easier to tap the rear speaker wire from the HU and used the converter to convert it to the RCA wires and connect the RCA to the amp.
This was recomended by stereo shops and on many othe forums.
But hey, if it works, it works.
...Ben
sbsolara84
Postby Sol-Toy » Tue Aug 29, 2006 8:24 pm
You need this: Navone N-85V.
http://www.davidnavone.com/adaptor_products.htm
Make sure you get the one with the "v"...you can adjust the level of noise. I just bought it last week to connect with my 00 Lara. I haven't installed it properly yet (hence my latest thread)
But it apparently works flawlessly and you can adjust the loudness levels — includes dial that the non-v 85 offers.
It's under $30 and they shipped it to me in less then 5 days — incredibly fast!
2013 WRX Wagon Premium in crystal black silica - current
2012 RAV4 S - Wife's
2000 Solara 1mz - sold after recording 160k mi
https://www.instagram.com/andygriesemer/
Sol-Toy
Users browsing this forum: Google [Bot] and 9 guests
