SolaraGuy.com • View topic - where have you guys mounted/grounded your amps
Postby hari-bhari » Fri Aug 11, 2006 6:21 pm
i mounted mine on the back of the passenger-side rear seat. its grounded to a place a shaved down on the inside of the trunk. has anyone found a better mounting/grounding spot?
hari-bhari
Postby woa_its_j3ff » Fri Aug 11, 2006 6:56 pm
back left rear seat is where mine is.
Postby unbalancedwood » Sun Aug 13, 2006 9:47 pm
The sides of the wheel well...
Really just depends on where your amp is, you want the ground to be less then 3" long. As long as you sand the paint down good, your alright...
unbalancedwood
Users browsing this forum: Google [Bot] and 9 guests
