SolaraGuy.com • View topic - Q for CDplayer connection
Postby wanfish » Fri Aug 25, 2006 4:30 pm
Hi guys ,
Thanks for all the help from u and I got some new Q now .
I just got a KENWOOD KDC-MPV7019 MP3 CD PLAYER ,what should I do to connect it with my speakers and bypass the stock AMP ? I went to a store but they don't have that kind of harness .
thx
I just read the guide :2000 Camry Solara audio install guide (fwd)
But so bad I did not see the white connector in the right empty hole in my car ,1999 SLE . (On the right side inside the hole will be a
white connector assembly. Pull the 2 connectors that go to the assembly
(again using the push-in tabs). You now are holding the Toyota standard
2-connector radio wiring harness)
wanfish
Users browsing this forum: Google [Bot] and 9 guests
