SolaraGuy.com • View topic - Amp install — Which wire for remote?
Postby Sol-Toy » Wed Aug 30, 2006 1:21 pm
So I got around my N-85V issue. The subs sound great (with some minor adjusting here and there) but I can't figure out why the amp and subs stay on when the ignition is turned off.
I turn the car off and the subs start playing loud consistent base. Just base...
any thoughts?
2013 WRX Wagon Premium in crystal black silica - current
2012 RAV4 S - Wife's
2000 Solara 1mz - sold after recording 160k mi
https://www.instagram.com/andygriesemer/
Sol-Toy
Postby Sap Z » Wed Aug 30, 2006 1:26 pm
yea my car did tht..
but my sub is powered through the amp on my rear speaker..so..it goes off after a lil bit though
SapZ
V6 SE DWP
Sap Z
Postby Turbosolara » Wed Aug 30, 2006 1:28 pm
the ampilifer has a wire is remote wires, the installer connect the wires with something that has consant voltage which is incorrect.
the purpose of the remote wire is a switch that when it sense electric, it will turn the amp on and vice versa. usually the aftermarket headunit has a wire for this
Postby Sol-Toy » Wed Aug 30, 2006 1:35 pm
Turbosolara wrote:the ampilifer has a wire is remote wires, the installer connect the wires with something that has consant voltage which is incorrect.
Do you think it's because I installed the remote wire to the thick Blue/Yellow wire instead of the thin Blue wire?
Sol-Toy
Postby SolaraPete » Wed Aug 30, 2006 7:41 pm
More than likely. Whats happening is that "blue" wire is not a switched power source, so even with the key off the amp is staying powered up and amplifying the "noise" coming in thru the rca's. Just connect the remote wire (the blue wire) to a switched power source either behind the radio or in the fuse box and put a 5 amp fuse inline to keep everythig safe.
SolaraPete
Postby Sol-Toy » Wed Aug 30, 2006 8:11 pm
any idea of which wire is a switched power source in a 00 Solara (color?) Because otherwise, I'm gonna have to mess with the fuse scenario :(
I tried the thin blue wire...it didn't work. Also found this:
Still not sure which color to go with :(
...man...my civic audio wiring was a walk in the park compared to this :(
Sol-Toy
Postby SolaraPete » Thu Aug 31, 2006 7:26 pm
U should really use a digital mutimeter when splicing into any factory wiring. See if you cant borrow one then drop $20 at sears for a cheap one - guessing at wires is a bad idea. Sorry off the top of my head i have no idea what color wire you could go to.
SolaraPete
Postby Sol-Toy » Wed Sep 06, 2006 4:57 pm
I used the accessory wire...gray one....either way, only one sub plays, and if I turn the radio off, both subs play noise :mad:
Sol-Toy
Postby DaTwUnKrAziEpInOy » Wed Sep 06, 2006 5:42 pm
Hey Sol-toy....you have an aftermarket headunit correct ?? If you do then the harness that connects to your head unit should have one. Usualy it's a solid blue or blue/white.
DaTwUnKrAziEpInOy
Postby made in china » Wed Sep 06, 2006 5:49 pm
oops, double posting
Gettin' pirate eyed.......
2002 BSP SE V6 5 Speed
TRD RSB
5000K HID Headlights
3000K HID Foglights
Gen 1.0 Tails
Optitron Lexus Cluster
made in china
Postby made in china » Wed Sep 06, 2006 5:50 pm
If you're hooking up to a OEM HU that has a outboard OEM amp like JBL, use the red wire. That is "AMP ON" power on/off.
If you have the basic HU, I dunno what to say.
TRD RSB
3000K HID Foglights
Gen 1.0 Tails
made in china
Postby Sol-Toy » Wed Sep 06, 2006 9:07 pm
basic...and the gray wire isn't my answere...ugh...aftermarket HU's are so much easier. I'm gonna look into the red wire tomorow. I'm almost 100% sure it's an inbord amp...we'll see if it makes a difference though...
Thanks all!
Sol-Toy
Postby made in china » Thu Sep 07, 2006 11:13 am
I know that the red wire is only present on the stock HU with outboard amp. Yeah, aftermarket HU would def be a good idea.
TRD RSB
3000K HID Foglights
Gen 1.0 Tails
made in china
Users browsing this forum: Google [Bot] and 9 guests
