SolaraGuy.com • View topic - My friend need help
My friend need help
My friend need help
Postby Peter » Sat Mar 01, 2003 5:14 pm
here's what my friend says happens to his system:
at high volumes, i get a quick "pop" and my whole sound goes out. i turn off my head unit, and turn it back on, and the music is back. this only happens at high volumes. 18+ on my alpine hu. i thought i could've been that i overpowered the amp, so i changed the settings, and i still get the same problem at the same volume. has this happened to anyone? any suggestions? its really scary hearing that stuff because i put so much money into my system. please help.
Sound System:
Head Unit: Alpine CDA-7893
Front: MB Quart PSD216 6.5"
Rear: Infinity Kappa 63.5i 6.5"
Speaker Amp: Eclipse 32440 4-ch
Sub: Infinity Perfect 12.1 12"(not installed yet)
Sub Amp: PPI PCX-1250 Mono(not installed yet)
Capacitor: Stinger 1 farad cap
Wiring/Accessories:
- Stinger 0g amp wiring kit
- 10g speaker wire
- Stinger 250a fuse block
- Lightning Audio dist. block
- Stinger positive battery term.
Sound Deadening: Raammat 60 v2 on all 4 doors
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby TadS » Sat Mar 01, 2003 5:24 pm
I would try doing a quick head unit swap. Alpines don't usually go bad, so that is a bit strange. Keep us posted, as I am interested in the resolution of this problem.
TadS
Postby Yanks0114 » Sat Mar 01, 2003 5:34 pm
Could you be overheating the amp? Is it after running the car for a while?
Postby Peter » Sat Mar 01, 2003 5:36 pm
he said it happens when his volume hits around 20 and he turned down the amp gains and the same thing happens. i think its the head unit, but not sure.
Visit Black Sheep
Peter
Postby Yanks0114 » Sat Mar 01, 2003 5:39 pm
Wait, I'm confused. Is it on your car, or on your friends car. Were the stats that you listed for your car or your friends?
Postby TadS » Sat Mar 01, 2003 5:43 pm
I think when those amps heat up too much they should just shut down. That is what mine do if they get too hot. The pop could originate in the head and be carried by the RCAs. Just a theory, but plausible I think. Maybe the head unit is getting too hot?
TadS
Postby Peter » Sat Mar 01, 2003 6:34 pm
Yanks0114 wrote:Wait, I'm confused. Is it on your car, or on your friends car. Were the stats that you listed for your car or your friends?
its on my friends car. listed is his stuff, very similar to mine, but its his.
Visit Black Sheep
Peter
Postby Gunman » Sun Mar 02, 2003 9:16 am
you have a voltage drop somewhere in the line. it can be several things, first, did he wire the alpine to the battery?, do all of his amps have the proper fusing, and then check the voltage on the battery and then the alt. :cry:
Gunman
Postby Yanks0114 » Sun Mar 02, 2003 12:09 pm
Gunman to the rescue :D On the Alpines they need like 10 gauge wiring directly to the battery. That just gives you an idea how much power they are pulling
Postby Peter » Sun Mar 02, 2003 1:06 pm
i helped him do the install. i did it exactly like mine. our setup is almost identical expect the speakers. mine has been working great, i dont know why his would do this...
gunman, when i check the volt, what should it read? and how do i check it? while its running?
Visit Black Sheep
Peter
Postby Yanks0114 » Sun Mar 02, 2003 1:15 pm
I would assume you are going to use a continunity tester or a DMM (Digital Mutli Meter). Just turn the system on and attach the red lead on the DMM to the power wires and black to the ground. You should be running anywhere from 13.4-14.1 volts. Around 13.8 is normal for driving with a light load, but i have run as high as 14.1volts. You don't want anything over 14.4 and chances are, you won't even come near that.
Postby TadS » Tue Mar 04, 2003 7:03 pm
Hey Peter, did you guys get this problem worked out? Did the proper power run fix it?
TadS
Postby Peter » Tue Mar 04, 2003 11:05 pm
he's tryin to get his uncle to test the voltage. we'll see what happens
Visit Black Sheep
Peter
