SolaraGuy.com • View topic - ported or no?
ported or no?
ported or no?
Postby Dawgz » Fri Sep 08, 2006 8:39 pm
I wanna get a new sub box for my 10" sub.
IS it better to go with Ported or no? that band pass thing.
Im not really good with sub boxes so bare with me and dont flame haha.
I listen mostly to rap, basically Hard hitting bass.
Ex. music from e40 etc etc...
Postby st.augsolara02 » Fri Sep 08, 2006 9:14 pm
it just depends on what kind of sound your looking for if your more into SQ or SPL..a ported/slotted/vented box is going to give you more "bump in the trunk" but isnt goin to sound as clean and tight itll def rattle ur mirrors tho..but if your looking to get bass notes that are a li more crisp and sound good but still hit hard then go with a sealed box..also keep in mind ported boxes tend to be a bit bigger and heavier becuz the subs required space is more in a ported box then it would be a sealed box..so basiclly if you want it to sound good get sealed and if you want it loud and to move massive amounts of air and rattle the trunk then get ported
So long Solara...Hello IS300!!!
New Project: '01 Autumn Sky Pearl IS300
* tien coliovers, 5% tint, SRT intake, HKS Carbon-ti exaust, 7" touch screen DVD, 2 12" Kicker Comp VR's
st.augsolara02
Postby krawzyazn » Fri Sep 08, 2006 9:32 pm
you better go bigger the a 10 LOL
Postby theprodigy79 » Fri Sep 08, 2006 10:54 pm
Depends on what kind of sub you have... Certain subs are more oriented to sealed boxes, while others perform more naturally in ported enclosures... Most subs will do fine in both enclosure types, but for reference, what do you have?
As far as musical types listened to... It really depends on what you want to get out of the sub... A 10" sub will hit sufficiently with hip hop / rap, but it will not hit the lows that many Oakland artists or southern bump hit... 12"s are more of a compromise for hip hop, while still allowing enough accuracy to meet the needs of other music types such as rock, fast beat techno, etc...
Since you already have a 10, as I said, you should be fine with it... As for box types, the sealed box will give you a tighter roll off and expand your low frequencies... The ported enclosure (assuming you have one properly made to accomodate your specific sub) will hit louder within the tuned ported frequency range (and cause more resonance as well), however it will not hit the same lows or have as tight of a roll... Subs in ported enclosures tend to be able to thump quicker and harder, but this is not guaranteed...
For you, and the types of music you listen to (e-40 and the like have a lot of low roll rather than hard, fast beats), I'd recommend going with the smallest sealed enclosure your sub will allow... The less air space you have in your box, the louder and tighter your sub hits... You will lose some roll in return, however it's a compromise you gotta make (and it will still roll better than with a ported enclosure). You will also have a higher all around power handling with the sealed enclosure (meaning through all frequencies)...
Another perk of the sealed over the ported in our cars is the fact that they (as I previously mentioned) don't resonate as much... considering our cars are rattle boxes, this DRASTICALLY cuts down on musical interference and keeps it clean sounding.
Hope I've helped!
-James
theprodigy79
Postby Dawgz » Sun Sep 10, 2006 11:38 pm
^^ thanx alot, im gonna try to find the smallest box for my sub...ill post with the results
Re: ported or no?
Postby made in china » Thu Sep 14, 2006 6:44 pm
You are gonna want ported if you are using a single 10". I borrowed my friend's single 10" Pioneer in a sealed box, hooked it up to my old school V12 amp, and that thing hit seriously hard. When you port, you generally get a extra +3dB in trade for a little loss on sound quality. But rap music and ported boxes are made for each other. You'll get a good beat out of a single 10" in a ported enclosre. Just make sure the speaker and the box are matched to each other, or else it'll sound worse than you could ever imagine.
Gettin' pirate eyed.......
2002 BSP SE V6 5 Speed
TRD RSB
5000K HID Headlights
3000K HID Foglights
Gen 1.0 Tails
Optitron Lexus Cluster
made in china
Postby woa_its_j3ff » Thu Sep 14, 2006 7:23 pm
go ported, since you listen to rap. :D. boom boom boom!
Postby RichD978 » Thu Sep 14, 2006 8:17 pm
just buy my L7 already has a factory vented enclosure from kicker. Search it if you want "12 inch Kicker L7" it's the 06 series
RichD978
Suggestion
Postby JMSinMaryland » Fri Sep 15, 2006 6:08 am
You should go with 2 12" Pioneer Premier DVC's in a sealed box capable of running 300W RMS per and 500W MAX. I could get this to you for $350 :wink:
JMSinMaryland
Postby Ruski » Tue Oct 10, 2006 7:07 pm
i have a solid Momo box with CVR12 awsome sound
